| Simplicity 4208 Mud Mower Project | |
+4redlinemotorsportts craftsmancole k2500life petez13 8 posters |
petez13 New Member
Age : 24 Join date : 2013-08-20 Points : 3927 Posts : 17 Location : Maryland
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5163 Posts : 1135 Location : Southern Florida
petez13 New Member
| Subject: Needs Tires May 1st 2014, 10:08 am | |
| Yea, I just don't want to spend $80 a piece on itp mud lites or something like that. Do you have any recommendations for mud tires? | |
Age : 24 Join date : 2013-04-05 Points : 4754 Posts : 661 Location : New Smyrna Beach,Fl
Age : 27 Join date : 2013-03-18 Points : 7275 Posts : 3131 Location : raleigh nc
petez13 New Member
| Subject: Measuring Rim Size May 1st 2014, 11:33 am | |
| I know this probably sounds simple and dumb but how should I measure the size of my rims so i get the right tire size. Are back rims just generic? Thanks | |
| Subject: Re: Simplicity 4208 Mud Mower Project May 1st 2014, 11:41 am | |
| - petez13 wrote:
- I know this probably sounds simple and dumb but how should I measure the size of my rims so i get the right tire size. Are back rims just generic? Thanks
you can measure them if you want. Usually they are 8" tall and 8" wide or 8" tall and 10" wide. You could go by tire size too just doesn't acuity measure the rim width itself. | |
petez13 New Member
| Subject: Measuring Rim Size May 1st 2014, 12:07 pm | |
| Thanks that's true imma look at the tire. Thanks again I will keep you guys updated! | |
untrusty huskee Member
Age : 26 Join date : 2014-01-04 Points : 3870 Posts : 79 Location : Fulton IL
petez13 New Member
| Subject: Rim Tire Size May 1st 2014, 12:58 pm | |
| It says its a 18x8.5-9 So does this mean I could get any tire as long as it was a 9 for the width of the rim? | |
petez13 New Member
| Subject: Isn't yours Hydro? May 1st 2014, 1:05 pm | |
| No mine is not Hydro. I'm almost certain that it is a 810 peerless 5 speed transaxle | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5553 Posts : 1408 Location : Galway NY
| Subject: Re: Simplicity 4208 Mud Mower Project May 1st 2014, 1:15 pm | |
| - petez13 wrote:
- It says its a 18x8.5-9
So does this mean I could get any tire as long as it was a 9 for the width of the rim? the last number is the bead size (rim size) so you need to stay at that measurement. the first is the overall diameter of the tire, the 2nd is the width, and the 3rd is the rim size. on my tractor, stock tire is 23x8x12, and i just replaced them with 25x8x12 Kenda Executioners with no problems. so, you can go taller and wider, as long as you maintain the 9 inch bead. hope that helps | |
petez13 New Member
| Subject: Re: Simplicity 4208 Mud Mower Project May 1st 2014, 1:31 pm | |
| So I'm liking the 22x11-9 Carlisle Srykers on Amazon. They are like the Duro mud and sand but they will fit my rim. What do you think? | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4371 Posts : 467 Location : Greensburg, PA
petez13 New Member
petez13 New Member
petez13 New Member
| Subject: Making a Skid Plate May 2nd 2014, 6:55 am | |
| So after I got home yesterday the starter was making and grinding sound so I took the cover off to find this | |
petez13 New Member
| Subject: No Starter, Make a skid plate!!! May 2nd 2014, 6:58 am | |
| Well after the starter gear being toast I decided to start making a rough design of a skid plate out of some leftover light sheet metal. What do you guys think? | |
| Subject: Re: Simplicity 4208 Mud Mower Project May 2nd 2014, 10:27 am | |
| Good start but you should make it go the full length of the frame so it dont just scoop up mud and water and get all in the belts. | |
petez13 New Member
| Subject: Skid Plate May 3rd 2014, 1:52 pm | |
| True, I think i'm gonna make a couple more for the rest of the under side of the tractor so it will be covered. | |
Age : 34 Join date : 2013-11-02 Points : 6955 Posts : 2906 Location : New Jersey USA
