| | Gas Pedals | |
+5Bandit1 dangeroustoys56 fetters18 F150F250F350 Josh Blair 9 posters | Author | Message |
Josh Blair Member
Age : 26 Join date : 2011-10-16 Points : 4621 Posts : 41 Location : Mt. Pleasant TN
| Subject: Gas Pedals October 20th 2011, 6:36 am | |
| how did some of you do them? | |
| | | F150F250F350 Member
Age : 28 Join date : 2011-09-28 Points : 4656 Posts : 52 Location : Oskaloosa Iowa
| Subject: I like mine October 20th 2011, 12:00 pm | |
| I used a mounten bike cable and handle I cut some of the handle bar off and bolted it to the frame then I took the cable and hooked it up to the govener. Make sure you have a good spring pulling it back or it will sit there and rev to high. I dont use the govenering setup it is to slow not had a problem yet. will post video on my youtube when I get some time but I have been in a crunch this week. Hope that helps.
| | | fetters18 Member
Age : 26 Join date : 2010-12-18 Points : 4954 Posts : 59 Location : ohio
| Subject: Re: Gas Pedals October 20th 2011, 3:01 pm | |
| check out arlid365 and fearlessfront on youtube | |
| | | Josh Blair Member
| Subject: Re: Gas Pedals October 20th 2011, 5:05 pm | |
| - fetters18 wrote:
- check out arlid365 and fearlessfront on youtube
yeah i saw those, but i wanted to see all the different ones | |
Age : 53 Join date : 2010-02-10 Points : 6867 Posts : 1726 Location : Florida, USA
| Subject: Re: Gas Pedals October 22nd 2011, 6:24 am | |
| You have any spare tractor parts around? I did a gas pedal on my mod MTD for practically nothing - used the clutch pedal assembly off my wheelhorse ( it doesnt need it) , couple springs, couple brackets i had, some bolts and bicycle derailer cables. My mod tractors all use the governer, first i dont want to wreck a perfectly good motor and second if over revved the flywheel would explode . I pushed my mod murray to around 35-40mph - it was too unstable to attempt any faster speeds( it wouldve went faster)- it was nearly all stock and i used the governer. | |
| | | Bandit1 Member
Age : 29 Join date : 2012-08-21 Points : 4322 Posts : 43 Location : kansas
| Subject: Re: Gas Pedals August 29th 2012, 11:46 pm | |
| I know it's kind of off subject but what did you do to your tractor for it to reach those speeds and still use the governor? | |
| | | Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 4804 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: Gas Pedals August 30th 2012, 8:43 am | |
| Here's mine. I took a bike seat stem And using one of the Honda 250 handlebar clamps, I clamped the stem, and screwed the clamp to the frame. I then clamped the bike hand brake onto the stem. Reusing the deck engage linkage, a spring, and some custom fab work, attached it to the governor. To grip the lever better, I slipped a bike pedal on the handle. | |
| | | CornishMorgan Member
| Subject: Re: Gas Pedals August 30th 2012, 9:51 pm | |
| LOL! When I had gotten the spindle out the pedal, I began wondering how I would put the thing on. I got fiddling with it and, what do ya know, It stuck on it without any modification. Now my cowboy boots won't slip off. | |
| Subject: Re: Gas Pedals September 8th 2012, 4:28 pm | |
| Bandit1: the murray had a 18HP twin opposed on it and a 6 speed trans along with a 6" motor and 4" trans pulley and 8" wheels all around. Heres how i did the throttle with the governer on the twin: Another thing that made the murray hard to handle was i used a ATV brake handle for a throttle on the steering wheel as a first attempt at building one - not good for driving and trying to steer and shift all at once. And it had no brakes - another challange.... The smaller motors i tried would barely hit 15 mph- figured with a whole lot bigger motor it would move lots faster..... the MTD could barely get out of its own way - BUT after looking in my MTD owners manual from my 92 white, adjusting the speed control rod wouldve propelled it a bit faster - the PO on my 91 stock mower tweeked it, thing goes fast in 7th. Dont have my MTD together anymore tho...... | |
| | | TennesseeCowboy Member
Age : 28 Join date : 2012-08-05 Points : 4417 Posts : 124 Location : TEN-A-SAYY
| Subject: Re: Gas Pedals October 26th 2012, 1:14 pm | |
| Hey guys i'm in the process of mounting a pedal on my mower with a bike brake handle, but i cant think of a good way to mount it to the foot board..Any ideas?? | |
Age : 49 Join date : 2012-04-23 Points : 5490 Posts : 1089 Location : Galion, OH
| Subject: Re: Gas Pedals October 27th 2012, 5:15 pm | |
| Ive seen guys use a flat piece of metal and a door/gate hinge as a foot pedal . | |
| | | | | Gas Pedals | |
| Who is online? | In total there are 33 users online :: 1 Registered, 0 Hidden and 32 Guests RichieRichOverdriveMost users ever online was 412 on January 7th 2023, 7:59 am |
