| LT4000 Craftsman | |
+7Angchor Ariens YT11 kawasaki220 mr.modified Thunderdivine redlinemotorsportts Craftsman1998 11 posters |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4944 Posts : 1068 Location : New jersey
| Subject: LT4000 Craftsman July 26th 2014, 9:06 pm | |
Last edited by Craftsman1998 on February 4th 2015, 9:36 pm; edited 4 times in total | |
Age : 27 Join date : 2013-03-18 Points : 7275 Posts : 3131 Location : raleigh nc
| Subject: Re: LT4000 Craftsman July 26th 2014, 10:47 pm | |
| Looks like a solid idea! You better build a beefy front axle and steering for that amount of speed! | |
| Subject: Re: LT4000 Craftsman July 26th 2014, 10:54 pm | |
- Looks like a solid idea! You better build a beefy front axle and steering for that amount of speed!
have any ideas on how i should do that? | |
| Subject: Re: LT4000 Craftsman July 26th 2014, 11:01 pm | |
| - Craftsman1998 wrote:
have any ideas on how i should do that? Read stretches post on THIS thread. | |
| Subject: Re: LT4000 Craftsman July 26th 2014, 11:08 pm | |
have any ideas on how i should do that? Read stretches post on THIS thread. thanks for that helped a lot i'm not going to worry about steering yet just want to get it moving then i'm going to worry about that stuff | |
| Subject: Re: LT4000 Craftsman July 27th 2014, 11:19 pm | |
| Pulled the transmission out today got rid of unnecessary parts removed all those dumb safety switches | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6335 Posts : 2101 Location : Norway, Europe
| Subject: Re: LT4000 Craftsman July 28th 2014, 7:32 am | |
| Thats a nice build! Will you lower it or keep it that high? | |
| Subject: Re: LT4000 Craftsman July 28th 2014, 7:36 am | |
| i think ill leave it that high i want it to be good at offroading too so i want ground clearance | |
| Subject: Re: LT4000 Craftsman August 1st 2014, 7:14 am | |
| http://southjersey.craigslist.org/grd/4597229911.html Would the carb and some of the other parts from this engine fit on my 15 hp ohv engine because i wanted to buy it as a spare parts engine. this ones a 92 and my engine is a 94 so i wouldn't think the carb and other parts would be that much different. any info would be greatly appreciated. | |
| Subject: Re: LT4000 Craftsman August 1st 2014, 12:45 pm | |
- http://southjersey.craigslist.org/grd/4597229911.html Would the carb and some of the other parts from this engine fit on my 15 hp ohv engine because i wanted to buy it as a spare parts engine. this ones a 92 and my engine is a 94 so i wouldn't think the carb and other parts would be that much different. any info would be greatly appreciated.
Probably not. L heads and ohv's are two different shows. | |
Age : 34 Join date : 2013-11-02 Points : 6955 Posts : 2906 Location : New Jersey USA
| Subject: Re: LT4000 Craftsman August 2nd 2014, 11:35 pm | |
| I had one of those craftmans with that body I think. More or less. It might be early in the project, but i've got to ask about my favorite part. What are you thinking on the exhaust? | |
| Subject: Re: LT4000 Craftsman August 3rd 2014, 7:18 am | |
Probably not. L heads and ohv's are two different shows. ok thanks alot for that info | |
| Subject: Re: LT4000 Craftsman August 3rd 2014, 7:23 am | |
| - mr.modified wrote:
- I had one of those craftsman with that body I think. More or less. It might be early in the project, but i've got to ask about my favorite part. What are you thinking on the exhaust?
Hhmm for the exhaust i might have it come straight out under the tractor and split off into two exhausts and have them end right under the foot rests so it will keep them out of the way and heat the foot rests a little. what would you think of that idea? | |
| Subject: Re: LT4000 Craftsman August 3rd 2014, 7:29 am | |
| i've started coming up with ideas for direct steering for this build i just need some pipe,flat stock, tie rods some nuts and bolts and my welder. just trying to figure out how to do it so i get the full turning radius. | |
| Subject: Re: LT4000 Craftsman August 3rd 2014, 10:35 pm | |
| Exhaust sounds like a neat idea to me. What kind of welder do you have? | |
| Subject: Re: LT4000 Craftsman August 4th 2014, 7:05 am | |
- Exhaust sounds like a neat idea to me. What kind of welder do you have?
I have a 90 amp flux core welder its from harbor freight | |
Age : 23 Join date : 2014-01-22 Points : 4363 Posts : 546 Location : north carolina
| Subject: Re: LT4000 Craftsman August 4th 2014, 8:15 am | |
| you should run the exhaust right out the back just like you say but put the as close to the floor boards as possible it will warm your feet and if snow gets on them it will melt and if it comes out the back it will also warm your tranny | |
| Subject: Re: LT4000 Craftsman August 4th 2014, 10:13 pm | |
| Hood scoop or something? That flat hood looks like a good spot for something. Maybe leave the hood intact, but have some nifty stripes or graphics or something. | |
Age : 27 Join date : 2012-10-31 Points : 4956 Posts : 745 Location : The Wyo-Braska Panhandle
Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4211 Posts : 491 Location : Index, Washington
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6192 Posts : 1434 Location : east dublin georgia
