| New guy, first Off Road/ Utility tractor build. | |
+9Thunderdivine CornShuck4CE Ariens YT11 Creepycrawler redlinemotorsportts Craftsman1998 slim67 kawasaki220 steelshooter 13 posters |
| Subject: Re: New guy, first Off Road/ Utility tractor build. September 9th 2014, 11:39 am | |
| I love what your doing to this it's starting to look a lttle like my mower I love these old mtds there do easy to mod up look at my mower and one of the videos I put up I have got real cool febder flars on it that u can use and for the belt prob I have the same set up as u and what I did was get a cevlar belt on it and got a tighter spring from the dubble pulleys to the frame I have had water the the seat and I had no slipige at all | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4742 Posts : 919 Location : Defiance, Ohio
steelshooter Member
| Subject: Broke my transaxle! September 19th 2014, 10:38 pm | |
| With all the playing around I have been doing and hauling trailers that are clearly overloaded, I managed to break my welded transaxle. I took it all apart and found that my welds that I had done with my little flux core welder broke, but I have since gotten a good HTP Mig welder, so I cranked that baby up and spray welded that sucker back together. I'm sure this light weight transaxle will find another place to break, but we'll see. | |
steelshooter Member
Age : 23 Join date : 2014-01-22 Points : 4362 Posts : 546 Location : north carolina
steelshooter Member
| Subject: Locked rear is still good to go November 1st 2014, 8:18 am | |
| For all those that might be interested my locked rear trans is still holding up well. I am interested in getting a one different though, this system definitely has it's weak points. I picked up an older craftsman mower a while back and thought of using the trans off of that but that mower works so dang good as an actually lawn mower I cant bring my self to pull it apart. I got it for 25 bucks, from my neighbor who was moving. | |
Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3962 Posts : 347 Location : Downers Grove Illinois
steelshooter Member
steelshooter Member
Carshowkid Member
| Subject: Re: New guy, first Off Road/ Utility tractor build. November 2nd 2014, 9:17 am | |
| - steelshooter wrote:
- Thanks Carshowkid, they have some bite to em' that's for sure. The true test will be when I start to push snow with this machine and the snow plow I built for it.
nice! That will for sure be a test!... Is it hard to make a plow for a tractor? Is there a link I missed on this site??? Cause if I could build one... Then I don't have to buy one for $150-$300 | |
steelshooter Member
| Subject: Re: New guy, first Off Road/ Utility tractor build. November 15th 2014, 10:02 am | |
| It was pretty easy to build the plow, I did it in a weekend. I am really excited for the snow this year so I can try this contraption out. I think my biggest problem will be traction so I might have to find a set of chains for it, we'll see though. Thanks | |
Carshowkid Member
steelshooter Member
steelshooter Member
| Subject: Re: New guy, first Off Road/ Utility tractor build. November 17th 2014, 8:04 pm | |
| With the added 12v outlet, that make me want more electrical power for brighter lights and things, has anybody ever mounted a vehicle alternator to a mower and whats the best way of doing it? I have a pretty good idea for the brackets, but the electrical is my weak point. Thoughts? | |
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
Carshowkid Member
| Subject: Re: New guy, first Off Road/ Utility tractor build. November 17th 2014, 10:54 pm | |
| - LAWN MOWER MUDDER wrote:
- Make like  fearlessfront style pull start and attach an alternator to it. If you still want a pull start put a double pulley on the top.
that is your answer... Or attach it underneath the tractor... But then you risk getting it wet... Or put a pulley and a long rod going to the top of the tractor... (Under dash or something) with a pulley on the top of the rod and put the alternator there... But that would be mostly the same as a pulley on top of the engine | |
steelshooter Member
