Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | Need Help Removing a Rusted on Rim And Carb Issues. | |
Madmowers New Member
| Subject: Need Help Removing a Rusted on Rim And Carb Issues. October 17th 2014, 5:34 pm | |
| I need help my back left rim on my mower is rusted on and I need to get it off without takin the transaxle off any ides ? And also my carb is actin weird it will run fine but if I go over any bumps or any high vibration makes it die I do have a gas pedal on it and I'm not sure if it's the gas pedal makeing it flood it's self or what
Last edited by Thunderdivine on October 18th 2014, 5:31 pm; edited 2 times in total (Reason for editing : Proper topic.) | |
| | | Frankenvarna Member
Join date : 2014-10-08 Points : 3521 Posts : 27 Location : Southern Illinois
| Subject: Re: Need Help Removing a Rusted on Rim And Carb Issues. October 17th 2014, 6:00 pm | |
| Soak it with PB Blaster, Lay a block of wood across the back side of the wheel and beat it off with a big hammer. The block of wood will help keep you from bending the wheel.
The dying when you hit bumps sounds like the Coil "Kill" wire is grounding out. I'd check that first. | |
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
| Subject: Re: Need Help Removing a Rusted on Rim And Carb Issues. October 17th 2014, 10:18 pm | |
| Are these bumps like big bumps or small bumps? Could it be the seat switch that is making it die out when you hit bumps and lighten the pressure on the seat switch? If it isn't the seat switch then I would guess the coil wires but I'd think it just wouldn't start at all from those.
UNLESS they are hanging somewhere and only make contact when you hit bumps... | |
| | | jamcco Member
Age : 24 Join date : 2014-01-04 Points : 4007 Posts : 226 Location : New Hampshire
| Subject: Re: Need Help Removing a Rusted on Rim And Carb Issues. October 17th 2014, 10:28 pm | |
| my mower was doing the same "dying" over bumps thing. I ended up rewiring the tractor and it hasnt done it since, I am not sure what the culprit was, but this solved my problem. check out fearlessfront's rewiring video, this helped me alot. the stock wiring harnesses have a bunch of areas that could go wrong.
| | | | Frankenvarna Member
| Subject: Re: Need Help Removing a Rusted on Rim And Carb Issues. October 19th 2014, 12:12 pm | |
| No I tryed to build a "tire puller" like a pulley puller I have to 1/4 inch plates on top of each other with 2 holes near the end and a bolt welded in the middle to push on the axle. 2 bolts go through the back of the tire through the holes on the plate and pull there together and that should pull the tire off but all it does is bend the plate so I welded rods near the end to support the plate and that's as far as I've got | |
| | | Frankenvarna Member
| | | | jamcco Member
| | | | Sponsored content
| Who is online? | In total there are 25 users online :: 0 Registered, 0 Hidden and 25 Guests
