Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | Best tuner | |
+5Doc Sprocket Doug Ariens YT11 B440 matt-man 9 posters | Author | Message |
WellThatsSurprising Member
| Subject: Re: Best tuner September 11th 2014, 8:02 pm | |
| You may see some very small gains on a stock setup but none enough to warrant the four to five hundred dollars you would spend on a tuner. | |
| Subject: Re: Best tuner September 11th 2014, 8:12 pm | |
| - WellThatsSurprising wrote:
- You may see some very small gains on a stock setup but none enough to warrant the four to five hundred dollars you would spend on a tuner.
I totally agree. If you want a good tuner, you gotta fork the money. and im not sure if you'll even see a 10hp increase, or fuel mileage. Tuners are for diesels IMO. | |
| | | TheBeal Veteran Member
Age : 29 Join date : 2013-06-06 Points : 5504 Posts : 1398 Location : Central PA
| Subject: Re: Best tuner September 16th 2014, 12:59 pm | |
| Dump the lead out of your boots...
| | | | | Best tuner | |
| Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests
