| 2nd Generation Craftsman Lt1000 Offroad Build - (Pics) | |
Muddy Sunday New Member
Age : 25 Join date : 2015-01-08 Points : 3412 Posts : 11 Location : Georgia
willysjeepmb Member
Age : 28 Join date : 2014-11-23 Points : 3560 Posts : 101 Location : Elora, Tn
willysjeepmb Member
jamcco Member
Age : 24 Join date : 2014-01-04 Points : 4008 Posts : 226 Location : New Hampshire
| Subject: Re: 2nd Generation Craftsman Lt1000 Offroad Build - (Pics) February 25th 2015, 3:29 pm | |
| Looks to be alot like mine. Question on your atv tires/hubs on the front. I had the same setup on mine for a while and I'm curious to as how the hubs are working for you....is there any slop? Are those the rear hubs off of the atv? I was rocking a very similar setup for a while | |
willysjeepmb Member
| Subject: Re: 2nd Generation Craftsman Lt1000 Offroad Build - (Pics) February 25th 2015, 8:31 pm | |
| - jamcco wrote:
- Looks to be alot like mine. Question on your atv tires/hubs on the front. I had the same setup on mine for a while and I'm curious to as how the hubs are working for you....is there any slop? Are those the rear hubs off of the atv?
I was rocking a very similar setup for a while Right now my profile pic is way out of date. The one on the left is what I'm using on your pic. We have a Polaris Sportsman 90 and I just popped the tires off its rims and put them on my murray's rims. Used them on mine till I could afford bigger. I just cut some off the rim to let it slide on so I could put the clip back on. I have only put them on the front about 2 weeks ago and so far so good. I was going to use the hubs, but they were splined. This is how I used them before I upgraded. Also, this is my murray. Tomarrow if I can remember, I will get a updated pic of what I drive. | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 4944 Posts : 1068 Location : New jersey
| Subject: Re: 2nd Generation Craftsman Lt1000 Offroad Build - (Pics) March 13th 2015, 10:39 pm | |
I was rocking a very similar setup for a while My hubs were almost the exact same size as the original spindals so they fit almost like the original rims but had a little bit of play in them. I have scenes then put the original front wheels and tires back on This is my only photo of the front rims but the used all of the same clips and washers as the original rims and didnt have too much play in them. | |
Age : 34 Join date : 2013-11-02 Points : 6955 Posts : 2906 Location : New Jersey USA
Age : 23 Join date : 2014-01-22 Points : 4363 Posts : 546 Location : north carolina
| Subject: Re: 2nd Generation Craftsman Lt1000 Offroad Build - (Pics) November 25th 2015, 7:39 pm | |
| - kawasaki220 wrote:
- wow man this is a good looking rig, and I love them rear tires how do they perform over all? keep up the good work
Appreciate it man. And I actually found the tires on an old atv trail they were just thrown in the bushes so i grabbed them and put tubes in them. But other than that they work great for the differential not being locked. The size of them makes it almost like a limited slip differential and ive had them in mud as deep as the floorboards and they were still going. i would defiantly recommend a new set of them if you've got the money. ( or find a set in the woods ) | |
