| 1966 sears craftsman build | |
vpk New Member
Age : 33 Join date : 2011-11-13 Points : 4562 Posts : 10
| Subject: 1966 sears craftsman build November 15th 2011, 6:37 pm | |
| Hi guys, im new to this forum and so far have found it awesome! well i found this 1966 craftsman sitting in some guys backyard he was going to restore it and make it a ride on for his daughter. i picked up this little mower for $50 and a brand new 10hp tecumseh for $60 i was just wondering if anybody has any ideas on how i can make this a good offroading mower my old mower was a massey which i cracked the front axle on and the guy screwed me when he was welding it so i never got it back. well anyway if you have any ideas let me know the pictures are vague but you can get the general gist of the tractor [img][/img][img] [/img] [img] [/img][img] [/img]
Last edited by vpk on November 15th 2011, 6:45 pm; edited 1 time in total (Reason for editing : needed pictures) | |
Ford Boi Member
Age : 39 Join date : 2010-08-22 Points : 5260 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: 1966 sears craftsman build November 15th 2011, 11:00 pm | |
| Haha neat little tractor, kinda similar to my very first tractor. Although I am not sure what make mine was, but they have similar frames.
Edit: I also love the seat on your BMX!! | |
vpk New Member
| Subject: Re: 1966 sears craftsman build November 16th 2011, 5:29 am | |
| haha thanks i was trying to do some simple mods but idk where to start aha
and thanks its a new seat aha just came out | |
vpk New Member
Age : 53 Join date : 2010-02-10 Points : 6868 Posts : 1726 Location : Florida, USA
| Subject: Re: 1966 sears craftsman build November 17th 2011, 10:06 am | |
| Well, looks like a chain drive unit on the craftsman? Should be able to swap a straight axle and lift it some more using pillow block berings - larger front tires ( weld bolts on the spindle ends for the wider rims).
You could make a new front axle for the massy- get some box steel wide enough,drill a hole in for the swivel , make some spindles from 3/4" bolts , use 3/4" steel nipples for bushings - guarentee itll be stronger then the stock axle.
Im going to build some drop spindles for a couple mod projects from 3/4" bolts i scored from my dad ( retired plumber- has all kinds of stuff) .
You might also want to search for a welder- harbor freight carries a cheeper brand , or invest in a good welder, specially if youre doing plenty of mods.... | |
vpk New Member
| Subject: Re: 1966 sears craftsman build November 17th 2011, 1:24 pm | |
| yup chain drive things awesome no slip
thanks for the advise im going to look now about lifting it | |
| Subject: Re: 1966 sears craftsman build November 18th 2011, 7:53 am | |
| Youll need to extend the chain as well - for some speed changes, you can swap sprockets - TSC carries weld in center sprockets of different sizes.
Id get a larger set of front tires, then base the rear lift on that so it sits level - the front can be lifted by changing the swivel point lower, most times when lifting the front, people use either gas hatch lift shocks or automobile shocks to dampen the side to side motion. | |
vpk New Member
| Subject: Re: 1966 sears craftsman build November 18th 2011, 9:02 pm | |
| the wheels are weird they are tubeless and valve less and also have keyways holding them in place i would like to extened the axl;e but have no idea how | |
Ford Boi Member
| Subject: Re: 1966 sears craftsman build November 18th 2011, 9:49 pm | |
| You sure they don't just have old twisted tubes that pulled the stem out of the rim? Or do you have those ancient solid rubber tires? And extending axles is as easy as finding a spare trans with longer axles that fit. (which can be hard lol) Or making some rim spacers. Many different ways. Or wait. You have a chain drive. I think dangeroustoys56 had the idea of the strait axle, which would be best. | |
| Subject: Re: 1966 sears craftsman build November 19th 2011, 12:45 pm | |
| Sounds like the wheels on my 70 toro tractor - front wheels were a hard plastic - rear wheels were actually air inflated. At one time i had a set of regular LT sized tires on it . | |
vpk New Member
| Subject: Re: 1966 sears craftsman build November 19th 2011, 5:14 pm | |
| nope they are the solid rubber tires haha they are heavy as hell and i really need to get a welder any good ideas from harbor freight? | |
Ford Boi Member
| Subject: Re: 1966 sears craftsman build November 19th 2011, 9:43 pm | |
| - vpk wrote:
- nope they are the solid rubber tires haha they are heavy as hell and i really need to get a welder any good ideas from harbor freight?
Yep those solid tires suck. I had a set of some old front end, I hacked keyways in them and did a burnout on one of my old Rally racers till they caught fire. I'd say just look for some bigger, normal tires, or even some the same size for starters. | |
| Subject: Re: 1966 sears craftsman build November 20th 2011, 6:16 am | |
| Ford Boi : - i bet that wouldve been a cool video of that burnout. You could probably get a basic model MIG welder pretty cheep , i would use a better wire- i bot some there for my hobart and welds terrible - more then likely youll need a flux core wire because using a gas kit isnt cheep ( i have the guages and setup for solid core wire - tank is like $250 tho- i just use flux core) . Or watch sale ads around black friday- might come across a good deal on a decent welder from Northern tools, TSC - places like that. | |
vpk New Member
| Subject: Re: 1966 sears craftsman build November 20th 2011, 5:16 pm | |
| i was just looking at some from harbor freight but i dont know which to get a wire one is good? | |
| Subject: Re: 1966 sears craftsman build November 25th 2011, 1:33 pm | |
| The wire at Harbor freight is a cheeper brand - id look for a good brand of wire from miller or hobart - it should work in a cheeper brand welder- depending on what size wire you get, you need to get different tip ends also- keep that in mind. | |
Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5598 Posts : 511 Location : Southern WV
| Subject: Re: 1966 sears craftsman build November 25th 2011, 1:56 pm | |
| I run the HF wire in my mig cause I'm cheap. Plus the welding I do is usually not anything high quality or good looking. Just need to stick two pieces of metal together. If I hade the extra cash and was welding nicer projects I'd run better wire though. I'd also get the tank and actually have a mig rather than fluxcore, haha. | |
| Subject: Re: 1966 sears craftsman build November 27th 2011, 6:13 am | |
| Yeah itll work- its just not a very good looking weld is all - next spool i get will be a better one. | |
Ford Boi Member
| Subject: Re: 1966 sears craftsman build November 27th 2011, 2:01 pm | |
| Do any of you guys use a stick?? I've had my Lincoln 225 for 8 years or so now, never given me any trouble. Cost me around 300$ new. Rods are cheap. I prefer it over a MIG for anything but bodywork or exhaust work. | |
arild365 Member
Age : 28 Join date : 2010-02-11 Points : 5605 Posts : 320 Location : Canada, BC
| Subject: Re: 1966 sears craftsman build November 27th 2011, 2:22 pm | |
| i have a couple stick welders and a couple migs and i used pretty well all of em. I like stick for bigger stronger welds and i seem too get nicer welds from stick anyways, i use my migs fer thin stuff and quick welds cause its easy. They all have there uses and work well. I pree much like any welding really, just something im good at. | |
Guest Guest
| Subject: 1966 sears craftsman build November 27th 2011, 2:48 pm | |
| I use my flux core mig for every thing. I have built cat0 implements for the 195 and havent broke a weld yet. I dug about 2 dump truck loads out of the mud pit with a box blade/ripper and hauled it off with a rear scoop. made them out of 1/4 steel and the hobart 140 did a hell of a job |
