| | clutch doesnt work and pulleys wont work | |
MurrayMudder Member
Join date : 2011-12-11 Points : 4579 Posts : 42 Location : New Hampshire
| Subject: clutch doesnt work and pulleys wont work December 12th 2011, 5:19 pm | |
| hey guys, im starting to get angry. I put new pulleys in the front and rear. a 6in the front and a 4in the rear. i made two idler pulleys to kepe the original belt tight and needless to say... my clutch doesnt work anymore... it doesnt push in and im confused as hell. please guys... I NEED PICTURES OF YOUR UNDER CARAGE! i need to see some different pulley set ups to base mine off of. PLEASE | |
| | | CityRedneck Member
Age : 27 Join date : 2011-08-13 Points : 4937 Posts : 241 Location : Winter Park
| Subject: Re: clutch doesnt work and pulleys wont work December 12th 2011, 10:09 pm | |
| our belt is prolly so tight that you cant move your clutch. when sticks ram up under my tractor and tighten my belt i cant move my clutch unless the stick and or branch breaks. so get under your tractor and push the clutch. tell me if its jsut to tight or if its catching on something. | |
| | | MurrayMudder Member
| Subject: Re: clutch doesnt work and pulleys wont work December 12th 2011, 10:29 pm | |
| im pretty sure it was just too tight and messed up and lah blah blah, i stripped the chassis in the rear and i think im gonna lift it now and make my own clutch to fix all the problems | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4729 Posts : 208 Location : Tennessee
| | | | MurrayMudder Member
| Subject: Re: clutch doesnt work and pulleys wont work December 13th 2011, 6:11 am | |
| it works fine when the belts not im but i think that some of my idler pulleys that i put in are making it jam and restraining the clutch from moving. like im starting fresh so i dont have the deal with all this b.s. | |
| | | CityRedneck Member
Age : 53 Join date : 2010-02-10 Points : 6869 Posts : 1726 Location : Florida, USA
| Subject: Re: clutch doesnt work and pulleys wont work December 13th 2011, 7:57 am | |
| My murray would leap the instant i popped it in gear, i flopped it over a few times doing that- mine was due to too tight of drive belt, there needs to be some slipping when its not engaged . | |
| | | MurrayMudder Member
| Subject: Re: clutch doesnt work and pulleys wont work December 13th 2011, 3:02 pm | |
| thanks for the input, im gonna start taking it apart and working on the lift brackets today so ill keep pictures and info posted on my thread in the build section "Murray Mudder now Murray Monster Mudder" | |
