| And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) | |
+11murrayracer redlinemotorsportts Doc Sprocket muddstir TheRainbowBoxer jsisti845 cumminsbayou GenevaCustoms LAWN MOWER MUDDER richie thomas Renzo24441 15 posters |
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 10th 2013, 3:35 pm | |
| Yep! they're 3/4". I was gonna order those. I think they're $12 or something. But they say something about the keyway.. They don't mention the inner dia of the bearings...
The other one talks about 3/4 spindle but says that's on the flange side and 1" on the other side... Grrrrrr
I'll probably call them tomorrow....
Age : 23 Join date : 2013-04-08 Points : 5023 Posts : 913 Location : Central Pa
Age : 27 Join date : 2013-03-18 Points : 7297 Posts : 3131 Location : raleigh nc
Renzo24441 Member
Age : 48 Join date : 2013-10-19 Points : 3916 Posts : 47 Location : Shen Valley, VA
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 15th 2013, 3:38 pm | |
| just for sh!ts and giggles, I went to the local TSC and actually explored it for a good while... wow.. impressed!
they did have the bearings I ordered, but at the same price, so no difference, since they are thrown in the package with the hubs...
good finds tho! | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7132 Posts : 2914 Location : Ontario Canada
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 9:59 am | |
| I rather shop locally too.. nothing like the "feely/touchy" when looking for parts.. hahahaha THIS... what to do with it...... removing the whole thing will not work since you need them to "keep the space" for the front "axle" and structural strength of that part, I guess... but would cutting them be an option, while keeping the integrity of the front? I would have to take measurements once the front tires are mounted, and see what would happen if I lower/weld the front... I would like to lower it a little, but keep the pivoting on it... any simple ways to do this, that do not require welding?? lol and also... THIS.... nothing that a crap ton of penetrating oil wouldnt take care of, right? I saw quite a variety of pulleys yesterday at TSC... I saw they had the keyways in different sizes, but they all had the "bolt" on them... thoughts on this, please? | |
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 10:17 am | |
| Bolt as in Allen screw? Yeah penetrating oil could help, but I cut or hole-saw them and then spray the penetrating oil then get a small puller and pull them off. WARNING! Do not hammer the end of the input shaft and pull up on the pully, you WILL end up mushrooming the input shaft and the pully will not come off. Just saying... But Anyway nice build. | |
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5575 Posts : 1408 Location : Galway NY
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 10:24 am | |
| great input, as always!
I was very surprised to see this kind of rust on it, since EVERYTHING else on the mower has pretty much no rust at all... I just dont understand how this transmission pulley got so rusty.... not even the deck pulleys or anything underneath!
I am just curious about it... I will do the pulley swap back there eventually... I just want to make sure I can get the right belt for it... thinking ahead, I guess... I have this, I am also looking at exhaust... welding a pipe to the outlet of the stock muffler just to run it to the back, cutting those deck brackets on the picture above, and the gas pedal...
thanks guys! hope its a productive weekend, if youre working on something! | |
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 6:13 pm | |
| - Renzo24441 wrote:
- great input, as always!
thanks guys! hope its a productive weekend, if youre working on something! Best way to prevent the rust on the pully is to take the pully off like twice a year and grease it nice and good then put it back on. | |
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 11:10 pm | |
| - Renzo24441 wrote:
- Well *****.... Lug bolt pattern is 4.5"..... I'm ready to shoot somebody.... Wtfffff !!!!
I hope this galvanized hubs are easy to drill!!!! Sonofabbbb they shouldnt be too bad. if you weld it, dont breath the smoke, and if it smokes as you drill it, dont breathe it... i done that once, stick welding.. it screwed me up for about 3 weeks. it sucked | |
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 16th 2013, 11:35 pm | |
| Thanks, Willis!
Yeah I've seen all the warnings for galvanized welding... I'm not doing that... Hopefully they won't smoke while being drilled, but just in case I'm doing it in the backyard, totally in the open..
Thanks man! | |
Renzo24441 Member
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 18th 2013, 8:55 pm | |
| Thank you Doc, Red, Willis.... the BFH worked beautifully! All of them out... i think I made them as centered as I possibly could... and now all drilled out... just need to widen the holes, and off to Ace to get the bolts and nuts! I will just need to grind down possibly an 1/8" of the back of the hubs, so the clip covers the washers and holds the whole assembly in place! Thank you all for brainstorming with me on this so far! | |
Renzo24441 Member
Join date : 2013-06-01 Points : 4624 Posts : 578 Location : West Virginia
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 18th 2013, 11:21 pm | |
| that's cause they are, TBP!! lol... ordered them from BMI, but the lug configuration I have, SOMEHOW is not available anywhere I have looked...
from center to center of lug hole on the wheel, it is 4 3/8" or so... so I ordered these from them, and replacement bearings, since the bearings that came with them were too small.. it was a 5/8" bore, and I needed 3/4"....
so... now I only need to widen the holes a bit more, get the bolts and nuts, and it should be a roller...
even though I do need to grind down the back of the hubs, because there wont be enough space for the e clip to click in place to hold the front wheels.... thats gonna be a pain in the @$$.... hopefully this weekend, I will be done with it, so we can take it rolling... and see how it does...
pulleys, gas pedal, paint, all of that comes in the spring... right now I will just do wiring for lights, front and back... since we live in town... | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5515 Posts : 1091 Location : Galion, OH
Renzo24441 Member
| Subject: Re: And so it begins! Craftsman LT1000 ---> ATV (we are hoping!) November 24th 2013, 4:39 am | |
| lol well hopefully I wont have to change rims any time soon!! but... after talking with Doc and Red on options to either grind down the hub (it was too long) or removing the cup on the spindles, I went with cutting that s#!t out of it.. luckily Ace had the shaft collars I needed, so...... HERE IT IS!! got these lights from a friend of mine.... I tried using some LEDs I have for the tail lights, but to my amazement, the voltage I was getting from the headlights was 0.2v at full throttle... so they never worked... replaced them with a regular incandescent bulb, and worked fine... so for the driving lights, Im gonna have to connect them directly to the battery to get the 12v for LED driving lights... anybody has messed around with the wiring on these? any spot I could get constant 12v power after the engine is running? thanks guys! hope you like the finished FOR NOW project... | |
