I am using a mtd frame, what I have all ready done to it is, gutted the hole thing and I had split the frame so that it slides back in the back part of the frame so that the motor ( an 8hp for now ) and in time that motor will be a 40 cude, the trans is one from a mtd with a variator so it only has for word and revers, I will be using a ragerlar lawn mower belt clutch. I will be welding a chopper bicycle to the front in turn turning it into a trike.I will be using a 8" pulley on the trans and a 3" on the motor. I will use the rageular brakes that are on the trans, um I will have update videos on my YouTube.com/trevorlc100 . then I am hoping to make this in school at our welding shop. I'm not going to put the variator back in I'm only gunna have for words and revers, I had the idea and its gust for having fun on. I might paint it military green and black and the name is Te Drill Sargent.
Last edited by untrusty huskee on August 29th 2014, 3:36 pm; edited 6 times in total
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6205 Posts : 1434 Location : east dublin georgia
I am using a mtd frame, what I have all ready done to it is, gutted the hole thing and I had split the frame so that it slides back in the back part of the frame so that the motor ( an 8hp for now ) and in time that motor will be a 40 cude, the trans is one from a mtd with a variator so it only has for word and revers, I will be using a ragerlar lawn mower belt clutch. I will be welding a chopper bicycle to the front in turn turning it into a trike.I will be using a 8" pully on the trans and a 3" on the motor. I will use the rageular brakes that are on the trans, um I will have update videos on my YouTube.com/trevorlc100 . then I am hoping to make this in school at our welding shop. I'm not going to put the variator back in I'm only gunna have for words and revers, I had the idea and its gust for having fun on. I might paint it military green and black and the name is trike commander.
we're gone need pics
untrusty huskee Member
Age : 26 Join date : 2014-01-04 Points : 3883 Posts : 79 Location : Fulton IL
Your sign almost put me into a seizure- and I'm not even epileptic! LOL
Welcome to the build-off. I very strongly urge you to consider better brakes than factory- first, for your own safety, second- you'll have to demonstrate your brakes work to qualify as a finisher for voting.
like i said up above, i will also be posting updates on this project on youtube and the finishing video on here for the final voting, and the video will not only be a demonstration i will also drive it and try to get a top speed run, but thank you for qualifying this build
i cant help but notice your gascan is a bit ferfriggsakesed... i hate those new cans. i drilled a hole in mine, fished a valve stem through it, so i just undo the cap and it freeflows
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5251 Posts : 1311 Location : NW USA
i had finally got the frame and everything else at my school, and now i will be uploading pics when i will have his class next. and im hoping that he will let me do a video update.
Can any body tell me what kind of trans this it " /> " /> " /> I had looked it over and I could not find any markings no tags no nothing all I know is that its a 5 speed. Here's my vid of it.
Last edited by untrusty huskee on February 27th 2014, 5:16 pm; edited 1 time in total
Age : 27 Join date : 2013-03-18 Points : 7288 Posts : 3131 Location : raleigh nc
Started cutting the chopper frame. Actually its all cut but I ha e to take a picture of it later. Then I had cut the mtd frame flush with a plasma cutter.
