| extended axle HELP! | |
+2Hillbilly Homer greener179 6 posters |
greener179 Member
| Subject: extended axle HELP! June 18th 2012, 2:51 am | |
| my mower is very tippy off road and am looking for any idea's for extending the rear axle need idea's fast going on a camping\mudding trip and want it done | |
Hillbilly Homer Member
Join date : 2012-04-22 Points : 4642 Posts : 197 Location :
greener179 Member
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5053 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: extended axle HELP! June 18th 2012, 11:18 pm | |
| If its the common transaxle setup you could go to a machine shop and get someone to make you an axle with the keyway in it and c clip grooves but you would be expecting probably $200-$300 but it would also lock the rear end. | |
greener179 Member
greener179 Member
| Subject: Re: extended axle HELP! June 18th 2012, 11:43 pm | |
| and i put the old rear tires on the front and one locked up and i cant get it off and it wont spin at all | |
greener179 Member
W1ldyOvvnZ Member
| Subject: Re: extended axle HELP! June 19th 2012, 10:37 pm | |
| ummm, go to a store and look for an axle that is double the size you want each tire to go out(then cut it in half) and see how much they would sell one for and then get an old tire and cut the center out of it to connect the two axles together. It would work temporary then you could try to weld it upstraight. but that would be alot of work trying to get it straight and making sure it holds your weight plus the spinning motion. You might be able to get the axle done even cheaper if you find the right machine shop. | |
greener179 Member
| Subject: Re: extended axle HELP! June 19th 2012, 10:57 pm | |
| im figured out that im going to make hubs and spacers but im so mad about the front tire it wont do nothing wont spin or come off the spindle | |
dked41 Member
Age : 60 Join date : 2012-01-31 Points : 4610 Posts : 141 Location : central Wisconsin
| Subject: Re: extended axle HELP! June 20th 2012, 10:59 am | |
| What rim is on the front, is it stock front rim or a keyed rear style rim? Was it greased? I'm trying to determine the problem with your front wheel being stuck. Pictures would help with seeing what you have. | |
greener179 Member
| Subject: Re: extended axle HELP! June 20th 2012, 12:28 pm | |
| its the keyed rim from the back it was greased and sorry cant post pitures no camera | |
greener179 Member
| Subject: Re: extended axle HELP! June 20th 2012, 9:40 pm | |
| got the tire off but now my i forgot how i was going to make hubs and spacers | |
Jamus Established Member
Age : 44 Join date : 2010-06-28 Points : 5608 Posts : 511 Location : Southern WV
| Subject: Re: extended axle HELP! June 22nd 2012, 7:48 pm | |
| If you have a welder and spare 8" rims you could weld 2 together for width. If thats too wide ou could cut the spacer wheel down to the center. I've seen it done with a larger rim over a smaller, like a 10" over an 8", same idea. | |
greener179 Member
| Subject: Re: extended axle HELP! June 22nd 2012, 11:28 pm | |
| how do i put the c clip on if i weld the two rims together | |
greener179 Member
| Subject: Re: extended axle HELP! June 23rd 2012, 12:19 am | |
| could i bolt the two rims together with like grade 8 bolts | |
mowerstompin Member
Age : 31 Join date : 2012-06-14 Points : 4373 Posts : 28 Location : Central Arkansas
| Subject: Re: extended axle HELP! June 23rd 2012, 12:53 am | |
| Can you weld? Say with a stick (7018). If yes: You can but get a peice of round stock (tubing) thats the same size as your axle and weld it onto it. Bevel both sides (axle and new piece to weld on) then make sure there even and lined up straight with your axle, make a solid root pass around, grind it down a bit, then weld a filler pass. Then use a tiger disk to make it look like one solid axle. With 7018 and a good weld, I'd never worry about it breaking. Then use a matabo to cut your C-Clip and keyway grooves. Not that hard if you can weld/fabricate. I wouldn't do this if you have just some welding experiance, as a bad weld leads to a bad result. If no: (probably the easiar way out, maybe not the cheapest though) You could find some say 3/4 (if thats your axle size) hubs, weld them on the axle itself.. then find you some 4/4 pattern wheels to fit. Then you can just get spacers to get about whatever width you want. I dunno if any of this helps but I figured Id say something in the matter | |
greener179 Member
| Subject: Re: extended axle HELP! June 23rd 2012, 2:21 am | |
| i have never weld and dont have a welder could i do how poeple weld to rims together but insted bolt the rims together with like grade 8 bolts | |
| Subject: Re: extended axle HELP! June 23rd 2012, 11:15 am | |
| The bolting might work, but they'd need to be very long and you would need sleeves over them. Even then I don't know about it. | |
greener179 Member
| Subject: Re: extended axle HELP! June 23rd 2012, 1:51 pm | |
| well i might try with bolts today and see if it works do see why it wouldnt | |
