| FrankenHorse | |
+4truckin42 Jerbear0612 richie thomas craftsman30mph 8 posters |
craftsman30mph Member
Age : 31 Join date : 2011-08-23 Points : 4820 Posts : 127 Location : branch MI
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: FrankenHorse June 12th 2013, 3:39 am | |
| looks good man, some one in the back ground of that one pic looks jealous tho | |
| Subject: Re: FrankenHorse June 12th 2013, 8:49 am | |
| - richie thomas wrote:
- looks good man, some one in the back ground of that one pic looks jealous tho
yeah haha i still have quite a bit of work to do and parts to find... i'm going full offroader, putting an atv rack on it reese hitch, bumpers and fog lights and built in toolboxes, going to have 3 seperate pedals for my gas pedal, clutch and brake i even have a built in cooler under my seat too! | |
| Subject: Re: FrankenHorse June 12th 2013, 9:39 am | |
| sounds good man, i wish i had done a smaller lift on mine, then it be easier to offroad, but that will be the next one , ima do a lifted 4x6 next, with about 6" of lift all the way around | |
| Subject: Re: FrankenHorse June 14th 2013, 9:20 am | |
| got a little more done on it started on a bumper for it got the rearend bolted in and one of the hubs for the rear made.... working on it tomorrow too so pics should be up tomorrow or so... also decided to put 25's on the front too!!!! should be done soon, I can't wait! all I have left is one hub to make, hookup a clutch put my 25's on the front and wiring it up! and some smaller easy stuff | |
| Subject: Re: FrankenHorse June 14th 2013, 9:28 am | |
| heres a pic of me on it... sit about 7 foot high on this thing it's huge! | |
Jerbear0612 Member
Age : 27 Join date : 2013-04-23 Points : 4134 Posts : 89 Location : Salem ct
| Subject: Re: FrankenHorse June 14th 2013, 10:52 am | |
| I like it! Reminds me of fearlessfronts new lifted offroader | |
Guest Guest
| Subject: Re: FrankenHorse June 14th 2013, 11:45 am | |
| looks great, pretty clean build. I havent followed along with your build too much and now I see that was a mistake... good work |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5294 Posts : 1070
| Subject: Re: FrankenHorse June 14th 2013, 3:09 pm | |
| Thats a cool project you got there. | |
SuperMudMuppet New Member
Guest Guest
| Subject: Re: FrankenHorse June 14th 2013, 5:16 pm | |
| - SuperMudMuppet wrote:
- tires are huge on that
I like huge tires... those are about the same as mine in size on war machine, he just has a lift where I do not Still, a kick-arse build! |
Age : 27 Join date : 2012-10-31 Points : 4955 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: FrankenHorse June 14th 2013, 6:56 pm | |
| i like my 25"s on the front, and i love my 27"s on the rear they get alot of grip | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: FrankenHorse June 15th 2013, 7:56 am | |
| That's fantastic man! Have you locked up the rearend yet? | |
| Subject: Re: FrankenHorse June 16th 2013, 10:08 am | |
| locked rearend 25's front and back... put the front tires on ford festive rims and they bolted on my quad hubs:) 2 inch lift in front and 4 inch lift in rear still have to get a starter and wire up my motor and get a belt then she's almost done as far as getting it driving! I have the front bumper almost done and ready to put on.. then building a rear bumper with a reese hitch and i'll probably get my exhaust done today... 3/4 to the running boards then over to inch and a half to 3 and 1/2 inch chrome tips. similar to my old tractors exhaust | |
genegillis5 Member
| Subject: FrankenHorse June 16th 2013, 10:42 am | |
| Good morning , to you and your FrankenHorse project. I was looking for earlier posts of the build and couldn't find them. My project looks very similar. I have tires like you put ,on mine. But what kind of trans axle did you use and did it have the variable drive before you started. Mine is a MTD, but looks almost like your ride. I left my stock rear, but did away with the belts and just used the lever and clutch drive for the set up. Everything was aligned up. Mine is only 2 speed with reverse. The best I can tell it is already posi trac on the garden tractor I used, because the axle is soolid and goes all the way through the case. If you want check it out It's the Mtd ,handicap utility build in the off road section. I like your build good luck. | |
| Subject: Re: FrankenHorse June 18th 2013, 8:51 am | |
| well guys it's time to change the name of the mower it started out a wheel horse but now it looks like an mtd with the new hood i put on it.. so it's no longer a frankenhorse... calling it sasquach now lol will put pics up tonight | |
| FrankenHorse | |
