| | i need help whith tyres!!! | |
ThomasBuilds New Member
Age : 25 Join date : 2013-01-02 Points : 4150 Posts : 10 Location : Wales, United Kindom
| Subject: i need help whith tyres!!! January 7th 2013, 5:48 pm | |
| hi i want to get atv tyres for the rear of my off road lawnmower but im wondering if they will fit because i have tubes but the tyres are made for tubless will they fit please help! Thomas | |
| | | RCG Member
2016 Build-Off Finalist
| | | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7560 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: i need help whith tyres!!! January 7th 2013, 6:17 pm | |
| - ThomasBuilds wrote:
- hi i want to get atv tyres for the rear of my off road lawnmower but im wondering if they will fit because i have tubes but the tyres are made for tubless will they fit please help!
Thomas Tubes will go in any tire, all you gotta do is cut the valve stem off the rim if there is one on it. For fitment, you want to match your rim size to the tire. For example, if you have a 8" rim that is 7.50" wide, youre going to want a tire to fit your 8-7.50 rim. If your rims arent leaking though (rust holes) and the tires hold air (no dry rot), then you should be fine tubeless. Best way to test that is to mount your tire, fill it up to the required pressure and pour soapy water all over the tire and rim to check for bubbles. If its a puncture hole, it can be repaired. If it leaks around the bead (tire meets rim), you can have an auto shop reseat it for you with some bead sealer. If the rim is leaking it can be welded, but its tricky. If the tire leaks from a crack from dry rot, its toast and you need tubes. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | | Doug Site Owner
| Subject: Re: i need help whith tyres!!! January 7th 2013, 6:29 pm | |
| I forgot to mention, if you do go tubeless and you dont have a valve stem, you will need to put one in. An auto shop should be able to do it really cheap, I change valve stems all the time and its really easy to do, takes like 2 seconds. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Chopperhed Moderator
Age : 57 Join date : 2012-10-14 Points : 5045 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| | | | Sponsored content
| Who is online? | In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests
