| | Peerless wont move, need help! | |
Cr8zyB0b Member
Age : 27 Join date : 2013-01-02 Points : 4184 Posts : 30 Location : England uk
| Subject: Peerless wont move, need help! April 16th 2013, 11:35 am | |
| I am new to building off road mowers but i have managed with every thing so far apart from the transaxle. It was sitting out side for over 3 years before i retrieved the tractor when under close inspection i found that that it would not move forward so i thought it was in gear checked that the gear shifter moved and it did i tried what was supposable neutral still no luck so i stripped the tractor from the mower and found that the wheels would only turn in opposite directions and both would not go the same way at the same time this would happen in all gears!! really don't now what to do and it has put my build on hold and i don't really want to shell out for a new transmission before i test every thing else.. PLEASE HELP | |
Age : 49 Join date : 2012-04-23 Points : 5490 Posts : 1089 Location : Galion, OH
| Subject: Re: Peerless wont move, need help! April 16th 2013, 11:38 am | |
| You'll probably have to disassemble the transaxle to determine what the problem is. I could be debris from something stuck in the gears, or could be rust (reverse chain?), or any number of things. Sounds like the axles are free and the differential is working. | |
| | | Cr8zyB0b Member
| | | | Cr8zyB0b Member
| | | | greener179 Member
| | | | xxXMowerdudeXxx Established Member
| | | | Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7560 Posts : 3035 Location : Lebanon County, PA
| Subject: Re: Peerless wont move, need help! April 16th 2013, 4:06 pm | |
| Frozen caliper. Thatll happen with a steel to aluminum mesh, and its a PITA to break free in most cases.
Your tires are supposed to spin in different directions, that is because of a differential. To get them to go the same way all the time, you need to lock it. Fearlessfront and a few others have tutorials on YouTube, and there are a few how-tos on the forum here as well. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Cr8zyB0b Member
| Subject: Re: Peerless wont move, need help! April 16th 2013, 4:27 pm | |
| Yes the brakes pins where sized in causing the brakes to lock up I got them out and sand papered the pins.. thanks to every one for there help. | |
| | | Doug Site Owner
| | | | Sponsored content
| Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
