| | Tire size help? | |
WilliesBuilds Member
Age : 28 Join date : 2013-06-19 Points : 4360 Posts : 329 Location : Florida
| | | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: Tire size help? September 24th 2013, 4:49 pm | |
| 18x9.50-8 is a tire size, not a rim size. I assume it is the size of your current rear tire. Therefore, your rear rim is probably somewhere around 8x7".
No tires in your link above will be suitably sized. | |
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: Tire size help? September 24th 2013, 4:51 pm | |
| - WilliesBuilds wrote:
- Would this tire fit my 18x9.50x8 rim
http://www.overstockwheels.com/tires/lawn-tractor-tires.html no, the tire in the link is to narrow, your rim is a 8" rim, so you need a tire that will go on it, but it has to be wide enough to, the biggest in the link is 4" wide, that is to small, the thinnest tire that could go on that rim would be a 8" wide tire, and that would be tough to get it to set on the bead | |
| Subject: Re: Tire size help? September 24th 2013, 7:42 pm | |
| yeah thanks guys I forgot to write that was my tire size. thanks a lot for the help | |
| | | | | Tire size help? | |
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
