 Off road mower I want to build
deaddave
deaddave
Off road mower I want to build Empty
PostSubject: Off road mower I want to build   Off road mower I want to build Icon_minitimeMay 5th 2015, 6:05 pm
This is the off road mower I built in my head and am trying to put it in picture form.
I first searched Google Images and found a mower to start out with.
Off road mower I want to build GEDC0885
Off road mower I want to build GEDC0886
I then used Photoshop to make the changes to the mower.
Off road mower I want to build Mud%2BMower%2BIdea
Off road mower I want to build Front
What i want to do on the mower is 4 wheel drive; Large ATV type tires; extend the length
of the front end; Install an opposed twin engine setting long ways; Have the two exhaust
dumping out into one header; putting a wench  up front behind the grill with the rollers
in the grill; Would like for gas, break, and clutch to be seperate .
I am probly crazy. ( and no I can't spell )
PostSubject: Re: Off road mower I want to build   Off road mower I want to build Icon_minitimeMay 5th 2015, 7:50 pm
Neat ideas, there is a build series on youtube of a 4x4 john deere ( https://www.youtube.com/user/wetheralmaplefarm ) That explains the easiest way to make 4x4.
I have a opposed twin with 2 into 1 header sitting longways too if you havnt seen already. bolts up to how much 12.5 flat head single was using stock bolt holes
deaddave
deaddave
PostSubject: re off road mower I want to build   Off road mower I want to build Icon_minitimeMay 6th 2015, 12:59 am
Thank you. I will check it out
PostSubject: Re: Off road mower I want to build   Off road mower I want to build Icon_minitimeMay 6th 2015, 8:53 am
We used to run a Murray like that... Didn't scrap it because of the frame not holding up. Those frames/bodies are practically indestructible. Good base to start with.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
deaddave
deaddave
PostSubject: re: off road mower I want to build   Off road mower I want to build Icon_minitimeMay 6th 2015, 8:23 pm
Thank you. I have seen these used on youtube a lot for builds.
» Murray Off-Road Mower Build
» murray classic off road mower build
» Craftsman Off-Road Mower
» off road mower
» LMM's OFF-ROAD MOWER
