| | Engine swap | |
Dipshaw87 Member
Age : 29 Join date : 2014-01-02 Points : 3950 Posts : 135 Location : Vanderbilt, Pa
| Subject: Engine swap March 25th 2014, 8:36 pm | |
| I have a bolens g16x1 with a 16 hp tecumseh on it. It has a driveshaft that goes into a jackshaft then the pulley for the transmission. Does anyone know if I could replace that tecumseh with something different like a briggs or kohler? It's tired and burns a lot of oil. | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7111 Posts : 2914 Location : Ontario Canada
| Subject: Re: Engine swap March 25th 2014, 9:10 pm | |
| You should be able to, just make sure the shaft size is compatible. Bolt patterns tend to be fairly universal, but don't be too surprised if you have to make some slight modifications. | |
| | | Dipshaw87 Member
| Subject: Re: Engine swap March 25th 2014, 10:10 pm | |
| I was either thinking about putting an older kohler on it or a newer briggs or say screw it and throw on a diesel lol | |
| | | Mitch'sgarage Member
Age : 24 Join date : 2014-03-24 Points : 3735 Posts : 46 Location : Omaha, Nebraska
| Subject: Re: Engine swap June 16th 2014, 9:47 am | |
| Engine swaps are not too hard to do. I sapped a Tecumseh with a Briggs and the bolt pattern matched. | |
| | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4744 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Engine swap June 16th 2014, 4:05 pm | |
| Id say diesel they are pretty under rated people look at them and their like "Oh its only 6hp" costs the same as a 15hp but it pulls a lot harder than a 15 could 8D | |
| | | Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4212 Posts : 491 Location : Index, Washington
| Subject: Re: Engine swap June 16th 2014, 5:18 pm | |
| - Moose wrote:
- Id say diesel they are pretty under rated people look at them and their like "Oh its only 6hp" costs the same as a 15hp but it pulls a lot harder than a 15 could 8D
Can you run the small ones like this, on waste oil, and vegetable oil, like you can, the car sized ones? | |
| Subject: Re: Engine swap June 16th 2014, 5:26 pm | |
I want to test it with veggie oil but Im going to have to do some mods to get the compression up because as it sits it doesnt have the compression to pop off the oil or so I have been told... | |
| | | Angchor Member
| Subject: Re: Engine swap June 16th 2014, 5:39 pm | |
| - Moose wrote:
- I want to test it with veggie oil but Im going to have to do some mods to get the compression up because as it sits it doesnt have the compression to pop off the oil or so I have been told...
I've read that when that is the case, you should start it with regular diesel. Then, after it has warmed up, and while running, switch it to the waste veggie oil. So you'd have to have two tanks. And some way to switch between them while it is running. Switch back to the diesel and let it run long enough to be running on diesel again, just before you turn it off. | |
| Subject: Re: Engine swap June 16th 2014, 5:55 pm | |
Switch back to the diesel and let it run long enough to be running on diesel again, just before you turn it off. Yeah I have also heard people talking about 50/50ing it so you have a 2 cycle mixture pretty much but I was thinking about it and was like well thats pointless because it sips fuel anyway I ran it pretty much all day sunday and used a quart of fuel... | |
| | | Angchor Member
| Subject: Re: Engine swap June 17th 2014, 12:55 am | |
| - Angchor wrote:
- I WANT ONE!!!
worth every penny youll spend on one though if you do get one just spend the money and get a yanmar the china diesels seem to have a lot of issues with material quality in their castings and bearings... | |
| | | | | Engine swap | |
| Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
