| | Craftsman 2 GT6000 kohler 18hp | |
Celicasupra86 New Member
| | | | CraftsmanQuad19 Veteran Member
Age : 23 Join date : 2016-04-12 Points : 5747 Posts : 2619 Location : Indiana
| | | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: Craftsman 2 GT6000 kohler 18hp March 10th 2017, 11:15 am | |
| Just out of curiosity, how are you going to get oil to the bearings of that turbocharger? Unless it's a pressure lube engine, which it could be. I may not be a fan of turbochargers, but I know the bearings in 'em need to be lubricated hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Craftsman 2 GT6000 kohler 18hp March 10th 2017, 12:09 pm | |
| I would run a separate oil supply for it if it was me. Whole separate system. The oil would last longer. Turbos get super hot, so that oil would be in the engine too, it would raise operating temps, and it just wouldn't be happy. But with a separate oil supply, the engine oil will be cooler and the engine will be happier | |
| Subject: Re: Craftsman 2 GT6000 kohler 18hp March 10th 2017, 1:23 pm | |
| Yeah that would probably work pretty good. Could even run it by a spot on the engine where the cold air from the flywheel exits the shrouds. That would maybe help cool the oil a bit. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 36 users online :: 0 Registered, 0 Hidden and 36 Guests
