| Gas Pedal?? | |
+2nathan wilson lt1000mudder 6 posters |
lt1000mudder New Member
| Subject: Gas Pedal?? July 3rd 2014, 12:49 am | |
| I have a foot throttle control welded up on the foot rest of my mower. its a brake lever from a bicycle and it has the conduit with the wire inside and the throttle that is on the dash hooks up with a lil metal rod with a bend in it. im wondering how to hook up the bicycle conduit so I can work the throttle with the bicycle lever on my foot rest. I really want to throttle with my foot. thank guys | |
nathan wilson Member
Age : 24 Join date : 2013-12-15 Points : 3855 Posts : 56
| Subject: Re: Gas Pedal?? July 3rd 2014, 8:42 pm | |
| - lt1000mudder wrote:
- I have a foot throttle control welded up on the foot rest of my mower. its a brake lever from a bicycle and it has the conduit with the wire inside and the throttle that is on the dash hooks up with a lil metal rod with a bend in it. im wondering how to hook up the bicycle conduit so I can work the throttle with the bicycle lever on my foot rest. I really want to throttle with my foot. thank guys
did you want it to be with the dash lever AND the foot petal? what kind of engine is it? i have a way for both opposed twins AND single cylinder. with the single cylinder you can have the lever with it. let me know. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: Gas Pedal?? July 4th 2014, 10:06 am | |
| I want just the foot pedal. I do have a return spring for when I let off the pedal it returns the throttle block to the idle position so that's not a problem. My problem is the thing that hooks to the throttle block is metal rod and it just hooks into the side. The bicycle conduit has the wire and I have no idea how to hook it to the throttle block so I can control the throttle with the foot pedal? | |
| Subject: Re: Gas Pedal?? July 4th 2014, 10:30 am | |
| Look at the thread I posted the link to above. The answer lies within.
| Subject: Re: Gas Pedal?? July 4th 2014, 12:32 pm | |
| yours is not the bicycle brake handle lever which is what I have and wanna use. its on a 17hp briggs ohv single engine. need to know how to hook it up to the carb | |
Angchor Member
Age : 66 Join date : 2014-04-14 Points : 4210 Posts : 491 Location : Index, Washington
| Subject: Re: Gas Pedal?? July 4th 2014, 1:05 pm | |
- yours is not the bicycle brake handle lever which is what I have and wanna use. its on a 17hp briggs ohv single engine. need to know how to hook it up to the carb
Your answer is in his link. | |
| Subject: Re: Gas Pedal?? July 4th 2014, 2:20 pm | |
| did u just drill a small hole thru the white throttle block? looks plenty good enough to hold
| Subject: Re: Gas Pedal?? July 4th 2014, 7:02 pm | |
| sorry man i just seen that you didnt use a bicycle brake lever for your pedal and backed out. now that ive actually read it i feel like a dummy lol. ur very detailed about how to hook it up with that cheap white plastic block and im confident that i can get my on now. also if anyone knows where i might be able to order some of that bicycle cable with the sleeve over it just for use when i need it. thanks for the info | |
| Subject: Re: Gas Pedal?? July 4th 2014, 7:19 pm | |
| LOL. I ain't gonna steer you wrong. You can get a "universal bicycle brake cable kit" at Walmart and various other places, containing about 5' of cable, the flex conduit, and a couple ends. That's what I usually use. | |
Angchor Member
| Subject: Re: Gas Pedal?? July 4th 2014, 7:24 pm | |
| If you want something stronger, look for the parking brake cables with housings for things like later model isuzu amigos, and such. | |
| Subject: Re: Gas Pedal?? July 4th 2014, 7:29 pm | |
| Indeed! I use surplus automotive parking brake cables when I'm setting up cable-op brakes on go karts and stuff. Bulletproof. Honestly, overkill for a throttle, tho- the cable is so thick and heavy, I think it would cause throttle problems. At the very least, you'd need some SERIOUS return springs! | |
Angchor Member
| Subject: Re: Gas Pedal?? July 4th 2014, 7:30 pm | |
| - Doc Sprocket wrote:
- Indeed! I use surplus automotive parking brake cables when I'm setting up cable-op brakes on go karts and stuff. Bulletproof. Honestly, overkill for a throttle, tho- the cable is so thick and heavy, I think it would cause throttle problems. At the very least, you'd need some SERIOUS return springs!
I had the thought because I am thinking about using one for the brakes on the WHAMS. | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4027 Posts : 337 Location : Woodville Al
| Subject: Re: Gas Pedal?? July 4th 2014, 10:35 pm | |
| How bout the hood latch cable on cars plinty long and strong enough. I just use bike cables if it breaks there easy to find. I have a nice pedel on my tracter its even doc approved. Chech it out in my build. I think the build is on page 2 and more pix on another page. Its in my signiture. | |
Guest Guest
| Subject: Re: Gas Pedal?? July 4th 2014, 11:05 pm | |
| i have a busted van imma try and use the gas pedal outta it for my build lol well see how it goes |
Angchor Member
| Subject: Re: Gas Pedal?? July 4th 2014, 11:09 pm | |
| - MTD2fst4u wrote:
- i have a busted van imma try and use the gas pedal outta it for my build lol well see how it goes
I want to see that! | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: Gas Pedal?? July 5th 2014, 12:11 am | |
| im steelin the hydro control pedal and brake pedal off the motor i bought awhile back for the engine going to try to figure a way to make a parking brake, i think it would come in handy
| Subject: Re: Gas Pedal?? July 6th 2014, 10:56 am | |
| yeah man thanks doc. I will look at my local Walmart and see if they have it if not I guess I can order it offline no biggie..thanks for all the help guys. | |
| Gas Pedal?? | |
