| new tires | |
Age : 23 Join date : 2014-01-22 Points : 4362 Posts : 546 Location : north carolina
| Subject: new tires July 9th 2014, 11:52 am | |
| so i have 200 dollars and i need new tiers front and rear the front one are old and dry rotted and the rear ones are only 4 month old but they arnt 20 inches tall only 18 and they don't work in mud that good so i need a rear tires that can do good in mud, grass, trails , pavement and the treads wont brake off so im up too any suggestions please show pics of the tire as long each tires is less than 75 dollars thanks i need it to fit a 8 inch rim and smaller than 23 inches tall this is what my old tires look like i dont like them | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4742 Posts : 919 Location : Defiance, Ohio
| Subject: Re: new tires July 9th 2014, 12:03 pm | |
| the only prob is they dont go on a 8 inch rim ] i need it to fit a 8 inch rim and smaller than 23 inches tall | |
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
| Subject: Re: new tires July 9th 2014, 12:26 pm | |
| Just get regular Carlisle Ag tires. I tried them against my old chinese four-wheeler tires. They are ALOT better. They are all around good tires. They are made of a stiff rubber and you can run almost 0 psi in them. If you put them on a skinny rim you can probably run about 0 psi and you won't have to worry about slippage problems.
Mine are 20x10-8 and I have them on 6.50-8 rims. | |
| Subject: Re: new tires July 9th 2014, 12:29 pm | |
| - kawasaki220 wrote:
- the only prob is they dont go on a 8 inch rim ]
i need it to fit a 8 inch rim and smaller than 23 inches tall They are both for a 8 inch rim and under 23" | |
| Subject: Re: new tires July 9th 2014, 12:37 pm | |
| Oh I forgot to type this above.
For the front. You should get 15x5-6 carlisle snow-hogs. They are really good steering tires. As long as you have them going at least 5 mph they will self clean. I would take them over other front tires. If you want to get new rims as well I'd get the 16x6.5-8 carlisle snow-hogs, again awesome steering tires. | |
| Subject: Re: new tires July 9th 2014, 12:39 pm | |
| do you have a pic of these snow hogs and a link of where i can get them | |
| Subject: Re: new tires July 9th 2014, 12:41 pm | |
| i was maybe thinking about bear claws are those anygood ive seen redneckcomputergeak use them but i want to get stuck some times or theres no fun | |
| Subject: Re: new tires July 9th 2014, 1:04 pm | |
| Check out my build thread for my build-off rally, there you can see my tires. Also, I wouldn't get bear-claws on an FNR that is just recipe for disaster! Do ya get my drift??? | |
| Subject: Re: new tires July 9th 2014, 4:59 pm | |
| i found this for 49.99 but are they good for everything i wanted them to do | |
| new tires | |
