Welcome to the All-Terrain Lawn Tractor Forum! 2024 is the 10th and LAST ATLTF.COM BUILD-OFF . . . for now! |
| | direct steer questions | |
fast adam Member
| Subject: direct steer questions August 4th 2014, 9:26 pm | |
| i have a question on direct steering, how does it handle when going down a trail at slow speeds it looks like a bear to turn, and does anyone know of a no weld setup. | |
Age : 27 Join date : 2013-03-18 Points : 7285 Posts : 3131 Location : raleigh nc
| Subject: Re: direct steer questions August 5th 2014, 1:54 am | |
| - fast adam wrote:
- i have a question on direct steering, how does it handle when going down a trail at slow speeds it looks like a bear to turn, and does anyone know of a no weld setup.
I guess you could buy a go kart steering shaft already welded uo with the pitman arm... But direct steering is more used on the street (when its already moving and easy to turn) And high speed stuff for easy steering corrections. Offroading you want some reduction in turning. | |
| | | B440 Member
Join date : 2014-01-22 Points : 4006 Posts : 226 Location : Thompson, CT
| Subject: Re: direct steer questions August 5th 2014, 2:47 pm | |
| You could switch the wheel out and put handlebars from a bike on. That would give you more leverage for direct steering. | |
| | | fast adam Member
| Subject: Re: direct steer questions August 5th 2014, 4:57 pm | |
| I was hoping to do it as cheaply as possable and i do both going fast and trail riding, i could just ajust the pitman arm to be short so that way it will make a reduction | |
| Who is online? | In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests
