| Bolens 1050 tubeframe snowplow build | |
+4redlinemotorsportts TheBeal willis923 ZSmachines 8 posters |
ZSmachines Member
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
| Subject: Re: Bolens 1050 tubeframe snowplow build September 14th 2014, 1:46 am | |
| that is the same clutch setup as mine, and we have a VERY similar driveline. instead of the brake directly on the driveshaft, it looks like yours has an aux shaft out of the tranny for braking. very similar though | |
ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3783 Posts : 221 Location : PNW
1997 Murray Veteran Member
ZSmachines Member
| Subject: Re: Bolens 1050 tubeframe snowplow build September 17th 2014, 11:33 am | |
| Well I went out to start the old beast, and she wouldnt start and started dumpin gas all over the ground! After pulling the carb apart, i found a giant hole in the float! I silver soldered the float, and now it works great! Who knew! And yes 1997 murray i will probably start a thread if the craftsman and probably the moline puller | |
| Subject: Re: Bolens 1050 tubeframe snowplow build September 17th 2014, 12:10 pm | |
| well good you got it fixed!if you need it I have the 9hp briggs from my simplicity that looks idenical to that 16, so if you need stuff I can bring it to the pull this saturday. | |
untrusty huskee Member
Age : 26 Join date : 2014-01-04 Points : 3869 Posts : 79 Location : Fulton IL
ZSmachines Member
| Subject: Re: Bolens 1050 tubeframe snowplow build September 18th 2014, 2:18 pm | |
| The bolens will have a manual lift for the plow, probably hooked up to the old deck lift lever. And yes 1997 Murray I would probably just need the carb or float but that would be very helpful. | |
ZSmachines Member
| Subject: Re: Bolens 1050 tubeframe snowplow build June 11th 2015, 12:02 pm | |
| Well so after neglecting this post for some time lol I figure that I should get some recent pictures of the tractor. It is totally transformed lol.. now it is my main Puller.Hopefully pics up after school. | |
upnorthkid Member
Age : 23 Join date : 2014-05-11 Points : 3711 Posts : 44 Location : Land 'O' Lakes WI
| Subject: Bolens 1050 June 15th 2015, 11:53 am | |
| Hi, I just got a free Bolens 1050 Husky garden tractor in mint condition with plow and mower deck. It has a heavy duty Wisconsin engine. It still has the pto shaft and belts for the deck and the option for a snowblower. My plan is to leave it stock so I can use it to plow and mow, but I will be getting some 25in bear claws for the back vs the 23in stock tires and rims. Over all, it's very well built and I plan to use it as a utility tractor. upnorthkid Let me know any history about this tractor. Thanks. | |
ZSmachines Member
| Subject: Re: Bolens 1050 tubeframe snowplow build June 19th 2015, 1:16 pm | |
| Sorry about lack of pics.. I no longer have a computer and my phone is being ornery. Upnorthkid: The Wisconsin engine is imo the best motors ever produced. I would not, however get bearclaws. If it was me, I would make dual adapters and run duals. Also, if you cut lugs on your tires you can get way better traction while keeping the stock feel. I now have 2 of these tractors, the 1050, and it's slightly smaller brother, the g10. I am planning on using the g10 for a utility tractor. | |
ZSmachines Member
crafsmankiller Member
Age : 26 Join date : 2012-10-18 Points : 4684 Posts : 412 Location : livingston texas
| Subject: Re: Bolens 1050 tubeframe snowplow build June 21st 2015, 9:33 pm | |
| What happened to the 532cc single?? Those singles are freakin huge, my friends dad has 2 yazoos with those single cyl on them. I really like the tractor too | |
ZSmachines Member
| Subject: Re: Bolens 1050 tubeframe snowplow build June 22nd 2015, 1:00 pm | |
| It would have cost me 500$ in ignition parts and a rebuild kit. The is 13 hp Briggs is way better. Always starts instantly, and is good on fuel. And thanks btw.. lol. Usaually in the pulls I beat 1997 Murray but at the last one I picked the wrong gear and he beat me by 2 feet. I actually think that these bolens' are the perfect pullers.. | |
