| ZSmachines's Craftsman Rally mower | |
ZSmachines Member
1997 Murray Veteran Member
ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3783 Posts : 221 Location : PNW
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
| Subject: Re: ZSmachines's Craftsman Rally mower October 10th 2014, 1:58 pm | |
| It all depends what your needs for the tractor are. If you will be racing and have direct steer setup on it I would go handlebars. That way you can have a twist or thumb throttle and your brake setup on there. If you are doing romping with stock or modified steering (i.e. Rack& Pinion) I would leave the steering wheel. Remember if you will be romping with big meaty front tires you won't want direct steer. It would be hard to turn with the big tires. Now look at the ARMA racers. They run 13" or 15" tires or something like that. They are fine with direct steer, along with that you would want direct steer or modified steering if you will be going over about 30mph. It gets pretty sketchy.
PS- Modified steering can also include if you go through your steering and essentially "race prep" it. This means- Grease fittings, bronze bearings (or even new plastic ones), and just taking all the slack out of it.
It is all personal preference... | |
ZSmachines Member
| Subject: Re: ZSmachines's Craftsman Rally mower October 10th 2014, 10:55 pm | |
| I have direct steer, as I use the tractor as short transportation, and I was tired of the craftsman steering shenanigans so I ripped it all out and went direct. Switch those big beefy tires it appears to be fine o small super easy trails, but I haven't really gone on anything big yet.. | |
ZSmachines Member
| Subject: Re: ZSmachines's Craftsman Rally mower November 10th 2014, 7:19 pm | |
| Well small not much of an update, but the snow is supposed to come on Thursday, and I need to get this thing ready for winter romps. Any tips and tricks? Have never done it before.. | |
ZSmachines Member
| Subject: Re: ZSmachines's Craftsman Rally mower November 12th 2014, 2:24 pm | |
| If you want belly pan, sheetmetal would do just perfect. Now, if you are looking for a skid plate to bash off rocks you will need something thicker. | |
ZSmachines Member
ZSmachines Member
| Subject: Re: ZSmachines's Craftsman Rally mower November 25th 2014, 3:15 pm | |
| Well, i put the old hood back on, with new and improved baja lights and she is now sitting outside for the moment... | |
ZSmachines Member
| Subject: Re: ZSmachines's Craftsman Rally mower January 31st 2015, 8:24 pm | |
| Well, This mower is now "Dead" as i removed the motor for another mower. This will be my build off tractor, but it is gonna be pretty much opposite of a rally mower! Just wait till tomorrow LOL | |
