| James's project" Bertha " [2017 Build-Off Entry] [Finalist] | |
+6Lawren Wimberly AllisKidD21 Doug MightyRaze mr.modified Jimjim0288 10 posters |
Jimjim0288 New Member
2017 Build-Off Top 3 Winner
| Subject: James's project" Bertha " [2017 Build-Off Entry] [Finalist] June 2nd 2017, 8:19 pm | |
| My name is james un"jimjim0288" this is my tractor Bertha and I feel as though it's less then 50 percent completed . The only thing I really modified is the front axle which I cut the welds off the Chanel that braces the axle and put in one inch spacer and lifted the hood two inches to clear atv tires . I have not welded the axle brace back in yet . I also put in some diamond plate on the dash with gauges and led push buttons which none have been wired yet , and I have cut out some of the wording that was no longer needed like the electric pto crap for the mower deck . So here are the things I'm going to be doing to it ... •Change transmission from six speed between the legs to six speed on the fender and modify frame to mount it and set it further back then stock •build mount for a 2000lb winch for the front of the tractor . •weld in the support for the front axle and update axle with newer model with grease fittings . • update the steering or modify it to be tighter . • Finnish my wheel hubs " mounting surface isn't completely flat" • mount a 48inch snow blade to work with winch and turn side to side with the mower lift . • fine tweak the hood fitment • build a rear bumper/ brush guard to match the front • wire in the gauges / switchs / winch • take it all apart and repaint every inch • put it all back together and hopefully do well in the build off lol | |
Age : 34 Join date : 2013-11-02 Points : 6968 Posts : 2906 Location : New Jersey USA
Age : 49 Join date : 2016-09-06 Points : 15092 Posts : 10655 Location : Oklahoma
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7579 Posts : 3039 Location : Lebanon County, PA
Age : 25 Join date : 2016-07-10 Points : 8392 Posts : 5190 Location : Ontario Canada
| Subject: Re: James's project" Bertha " [2017 Build-Off Entry] [Finalist] June 19th 2017, 9:49 pm | |
| Looking good! Does this tractor have a Briggs engine? "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: James's project" Bertha " [2017 Build-Off Entry] [Finalist] June 19th 2017, 10:31 pm | |
| Oh ok, I thought so. Looks good so far! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Up date June 25th 2017, 5:11 pm | |
Age : 57 Join date : 2013-12-21 Points : 4610 Posts : 744 Location : Salem Illinois
| Subject: Re: James's project" Bertha " [2017 Build-Off Entry] [Finalist] June 26th 2017, 2:55 am | |
| Nice start man! Right now I'd humiliate 4 people for that 12 hp briggs flatty though.... I'm dyin for one for my (gasp) "grass cutter"
I'm currently wasting an 18 horse oppy on a rebadged MTD... if I ever actually got traction, I'd twist of the poor lil fnr axles
| Subject: Re: James's project" Bertha " [2017 Build-Off Entry] [Finalist] September 22nd 2017, 9:57 am | |
| Thanks and no job , I’m now a stay at home daddy , so money just got really tight lol thankfully enough I have pretty much everything I need to finish my tractor . I just got to find the time to work on it , we’ve been busy making our new home ours .. | |
| Subject: Re: James's project" Bertha " [2017 Build-Off Entry] [Finalist] September 22nd 2017, 12:40 pm | |
| - Jimjim0288 wrote:
- Thanks and no job , I’m now a stay at home daddy , so money just got really tight lol thankfully enough I have pretty much everything I need to finish my tractor . I just got to find the time to work on it , we’ve been busy making our new home ours ..
Nothing wrong with that, if it was planned. I know about making the new house "home" We just moved this past DEC. We are still unpacking and making some mods that work for us! | |
