| Murray "Green Machine" Mud Mower | |
+3upnorthkid Craftsman1998 thewisconsinredneck5160 7 posters |
thewisconsinredneck5160 Member
| Subject: Re: Murray "Green Machine" Mud Mower July 26th 2015, 3:18 pm | |
| Whoo! (Rick Flair style) got the 18 hp oppy running but it is obnoxiously loud when i rev it up so I got to work on that, probably something like what fearless did on his Murray. Also I have striped down the shroud and painted it gloss orange. " /> " /> | |
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5544 Posts : 1993 Location : Northern Ireland
Age : 25 Join date : 2015-02-16 Points : 3407 Posts : 40 Location : Brookfield WI
| Subject: Re: Murray "Green Machine" Mud Mower August 30th 2015, 12:06 pm | |
| OK guys and possibly girl, I have some updates and pictures. " /> in this pic i started trimming the hood without the shroud on, but abandoned it when i put the shroud on. I got the shroud on and it looks dern smexy. " /> I got a pair of 4.8x8 Carlisle x tracs for the fronts. (poser shot) " /> They are sweet tires and are really beefy, so they should hold up good. My neighbor said it looks like a drag tractor, which was pretty cool. I got a new 5 inch pulley for the front " /> but I need a belt for it, and am having trouble finding a 99x1/2 inch belt for it so any help would be appreciated. | |
| Subject: Re: Murray "Green Machine" Mud Mower August 30th 2015, 1:31 pm | |
| so I didn't want to cram any more stuff into one post, so i made two. here is some pics of my toolbox and my tow chain. " /> " /> I made the holders from 6x8'' shelf brackets " /> Now for the actual contents of the tool box " /> " /> inside i have all the sockets and wrenches that i would need to do 99% of the repairs on the trail, a multi bit screw driver, zip ties, swiss army knife, sharpie, 2 screw links, lighter, ground cloth to lay on, plastic bag, garbage bag, duct tape, cotter pins, spare key, latex gloves, and a first aid kit. there enough room left on top to fit a disposable water bottle in | |
| Subject: Re: Murray "Green Machine" Mud Mower September 16th 2015, 8:40 pm | |
| OK so I'm thinking about fuel storage, and as i don't have the means to weld up a rack so I'm thinking of alternative method, like a secondary fuel tank hooked up to the main one or 16oz aluminium bottles files with gas. Let me know what ya think about my ideas | |
1997 Murray Veteran Member
| Subject: Re: Murray "Green Machine" Mud Mower September 16th 2015, 11:53 pm | |
| I like the toolbox. For fuel tanks maybe you could mount one on the front of the frame with more shelf brackets. On finding a belt have you looked online or at local stores? I belive you could find one online, or a hardware store could order you one. | |
rstolz Member
Age : 40 Join date : 2014-10-18 Points : 3528 Posts : 45 Location : IL
| Subject: Re: Murray "Green Machine" Mud Mower September 17th 2015, 12:03 pm | |
| take a look at my thread, the rack i built is all just cut and bolted. the parts that are welded are for the hitch, the rest of it is simply bolted together and bolted to the frame. Mine's sized for a 2.5gal gas can, but you could definitely use a smaller can and fit a tool box.
If you want to keep yours, you could fit a small auxiliary gas can or 2 inside the tool box. If you wanted to get fancy, you can pick up backpacking stove canisters that have hoses, fittings and a regulator coming off the cap, and route that to your gas tank or to a T-fitting in line with your fuel line.
I don't like the idea of putting a gas can on the front. if anything, at that point I'd put the tool box out front and a gas can behind. That's just me though, I don't want a gas can in a spot with a high impact risk.
On a side note, the plastics used in laundry detergent bottles is the same as that used for gas cans, so if you need a cheap gas can, just save a couple laundry detergent bottles. | |
| Subject: Re: Murray "Green Machine" Mud Mower November 19th 2015, 10:17 pm | |
| thanks for the replies i didnt notice them earlier, and yeah im not big on the front gas tank either but i might relocate the tool box to the front somewhere and slip in a detergent bottle on the back | |
| Subject: Re: Murray "Green Machine" Mud Mower August 19th 2016, 10:27 pm | |
| Quick update - bad solenoid, got new one and no idea how to write it up, any help will be greatly appreciated thanks | |
brooke&simon New Member
Age : 48 Join date : 2016-10-02 Points : 2811 Posts : 24 Location : newyork
| Subject: Murray "Green Machine" Mud Mower November 12th 2016, 6:40 pm | |
| hi i really like what you have done so far it looks really nice and for your first build keep it up | |
