| | Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite | |
makenzie71 New Member
| Subject: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 27th 2018, 11:20 pm | |
| So clearly this is not the kind of build you guys are normally dealing with, but it's what I'm working on all the same...the "race mower" forums all seem dead. I got an MTD Signature 2000 in pretty rough shape...but the engine runs BEAUTIFULLY and I think it's perfect to build a little hot rod that I can chase my kid and his go kart around the yard with.
My plan currently is to install a centrifugal clutch on the motor and, in the long run, just run straight to a live axle...ditch the variable pulley setup and factory axle all together and just do a go kart setup. For now, though, I want to try and make it work with the varying gears.
My questions at present are:
have any of you guys experienced issues running a large drive pulley mounted to a centrifugal clutch? Looking under there I'm thinking I'm going to have to go at least 8" on the drive side. I just didn't know if that additional mass would mess with how the clutches work.
~and~
have any of you guys managed to get the kind of speed I'm looking for out of the variable pulley? If that's just not something I can expect to pull off, then does anyone happen to know what the final drive ratios on these early 2000's axles are? | |
| | | AllisKidD21 Moderator
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 27th 2018, 11:51 pm | |
| As far as the vari-drive thing, I think one big issue would come from over-speeding it. If you put a much larger pulley on the engine the vari-drive assembly would be turning substanially faster and it might wear out a lot quicker. Of course there could be ways to set up a grease fitting or two to slow down the wear, but I'm not sure. Also the ratio of those MTD single speed transaxles is very low because of the variable speed setup. I believe it's somewhere around 24:1. Also, welcome to the forum! Haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 28th 2018, 12:39 am | |
| 24:1 might not be impossible...
35mph comes out to about 36,960 inches per minute. A 20" tire has a circumference of 62.8 inches.
36960/62.8=588.5 (wheel RPM).
588.5 * 24 = 14125 rpm input
This engine has a 3600rpm peak...s0 14135/3600 = 3.92
So basically I need a 3.92:1 ratio...or approx. I could run an 8" up from and a 2" in the back...would probably lead to a lot of slipping. I'll probably have to run a jack shaft (will be slammed) so I could possibly get the variation that way. I don't think I could run the variable pulley that fast. The whole thing will really be spooled up.
If 24:1 is accurate I'll be better off going ahead and investing in the solid axle and pillow block bearings. Going straight to the axle I could run a 1:4 ratio and have access to a LOT more speed than I really need. It'll also be easier to set up a proper brake...but I'll loose the open dif (I will be on asphalt sometimes so this is a concern). | |
| | | biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 28th 2018, 10:33 am | |
| Were you driving the axle directly or still using the varidrive? What kind of drive ratio were you using to get your low flying 9mph?
I'll be swapping the grease out for oil if I go this route, but I'm pretty doubtful I will at this point. I also have a Murray and it has an actual transaxle...that might be my better option. | |
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 28th 2018, 10:56 am | |
| I was running an ungoverned single cylinder kohler with a 6.5 inch engine pulley, no vari drive, and a 5.5 inch pulley on the tranny. I even oil filled it after I fixed it and the bushings before that point were ok then after driving a while with the oil in it I could watch the slop in the gear set bushings. A spicer transaxle is a major improvement for a racing mower and a peerless is even better , look for a 930 or mst 205 or 206 model as they are oil lubed, but you can swap out the grease with oil on just about anything. | |
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 28th 2018, 11:16 am | |
| A Peerless 600 would be a nice choice too possibly because they are oil filled, have no shift keys, no reverse chain, etc. But yes, pretty much any transaxle would be an improvment over the FNR. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: Gearing suggestions...need 30~35mph out of an old MTD varidrive Signature 2000 Elite May 28th 2018, 11:42 am | |
| The peerless and spicer pieces would be nice, and I'll use one if I happen across one for the right price, but it's a hard sell to go out and buy one for this particular project lol. I'm just going to go with a kart type axle. It'll be easier and it's a known "works" solution...just didn't want to get that deep into it right at the beginning.
...depending on what the Murray has, anyway...I guess I need to go flip it over and see what's under it. | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
| | | | Sponsored content
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
