| [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] | |
+17Murraymountain tater195 diddie muddstir Crazy_Carl RichieRichOverdrive mrshaft696 Hillbilly Homer SebastianAlbrecht MatthewD prancstaman Double W Cross Ranch CraftsmanQuad19 MightyRaze Hillbilly Offroading TheBeal AllisKidD21 21 posters |
Age : 25 Join date : 2016-07-10 Points : 8384 Posts : 5190 Location : Ontario Canada
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 9th 2019, 11:05 pm | |
| Yep! That's pretty much the plan anyways, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15068 Posts : 10641 Location : Oklahoma
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 9th 2019, 11:37 pm | |
| That would be pretty cool actually. Also, with the hood cut and spade bit sticking out on the right hand side, I'm pretty sure we're looking at "hazardous" in the rear view mirror. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2018-02-27 Points : 3643 Posts : 1299
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 6:56 am | |
| I like it, but IMO the front axle is too far in the front! I would move it as far back, so the point of the grill that's sticking the furthest out, is flush with the front of the tires. But it's your build, your Decision, Just wanted to give U an advice what would look better. | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 8:17 am | |
| Hmmm, I don't know. If I moved it back that far it might ruin the suicide front end look that I'm going for. Also it wouldn't leave any room for the susension setup I wanna try. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 8:53 am | |
| - AllisKidD21 wrote:
- Hmmm, I don't know. If I moved it back that far it might ruin the suicide front end look that I'm going for. Also it wouldn't leave any room for the susension setup I wanna try.
hmmmm..... at least I would move them a little bit back, so hat everything would work. The Suspension, and the suicide front end. | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 2:54 pm | |
| Took a stab at widening the axle today, went pretty well. Decided to stick a piece of 1/2" flatstock in both halves and weld it to the back inside wall: Welded it a bit on the inside too, should be plenty sturdy. Then to make it flush on the top and the front I used a big piece of angle steel: Fit pretty good. I just trimmed the part that stuck out to give it sorta of an artistic angle look, haha. The front track width will be something like this: Should be good! Gonna make go-kart style spindles at some point too, so the axle will be about level with the front wheel hubs. Last thing I did was cut and pound out the old spindles. They were worn out anyways, so they were no good. Now I can start fresh with some nicer spindles. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
prancstaman Veteran Member
Join date : 2015-02-02 Points : 4893 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 8:11 pm | |
| Haha, funny that comes up again..... Just happened to find that little unit while scrap hunting today. Not sure whether I'll use it, but ya never know. I just thought it was funny since Mighty mentioned it earlier, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2650 Posts : 582 Location : Reeses Mill, WV
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 10th 2019, 10:13 pm | |
| LOL, Mighty. - Jeremiah R. Cooper wrote:
- @AllisKidD21 the stance is fantastic. Wow I've missed a lot. For some reason I'm not getting any Gmail notifications for your thread. Everybody else's I am but just not yours. At the bottom it says I'm still watching topic lol.
Thanks!! Yeah sometimes I don't get the e-mail notifications either, most of the time I do though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5756 Posts : 2623 Location : Indiana
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 12th 2019, 5:31 pm | |
| Well I collected a few front end parts for the ol' LT-08 today: That looks promising to me! Hahaha. I already have most of it planned out, so while it might not look like much, I should be able to make something out of this stuff. Well... hopefully anyways. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 13th 2019, 10:28 am | |
| Yeah, I should be able to make something work with that stuff. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 13th 2019, 1:58 pm | |
| Perfect! That means I can leave you all in suspense. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 20 Join date : 2017-06-09 Points : 5289 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [FINALIST] - AK's LT-08 Rat Rod Tractor Build [2019 Build-Off Entry] February 13th 2019, 11:12 pm | |
| Hahaha, you guys. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
