| | new here, and would like some help... | |
+10mr.modified redzz02 CraftsmanQuad19 Mister_Studabaker darkside0914 Murraymountain prancstaman AllisKidD21 MightyRaze loggers gogert 14 posters | |
| | | | loggers gogert Member
Age : 18 Join date : 2020-02-14 Points : 1775 Posts : 202 Location : U.S, virginia
Age : 34 Join date : 2013-11-02 Points : 6977 Posts : 2906 Location : New Jersey USA
| Subject: Re: new here, and would like some help... February 27th 2020, 10:29 am | |
| Not sure what brand of rear engine machine that you found but snapper transmissions aren't too bad in my experience. This is a well used one that I shortened the frame on and rigged up for pushing cars around the garage. So far it's held up way better than expected. We've probably moved over 20 cars with it by now. It'll push them in 1st or 2nd gear. The transmission is actually just a flat circle disk on the engine crankshaft and a rubber drive wheel rides against it. For lower gear, the rubber wheel rides near the center of the disk. For higher gear it moves towards the outside. The shifter has 5 or 6 notches but really you could put it anywhere in between. With this one being short, the front wheels usually are off the ground when pushing a car as it wedges itself up into the bumper. That puts a lot of pressure on the rear wheels for traction so it works well even without a locked diff. They're simply but pretty rugged. | |
| | | | Hillbilly Offroading Established Member
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2667 Posts : 582 Location : Reeses Mill, WV
| | | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8401 Posts : 5190 Location : Ontario Canada
| Subject: Re: new here, and would like some help... February 27th 2020, 12:26 pm | |
| - loggers gogert wrote:
- oh, so yours has gears? is it belt driven or chain driven?
More so "speeds" than gears on those Snapper RER's. They use a rubber friction drive, as mr.mod explained, essentially the same as a walk-behind snowblower drive system. No actually gears changing. There might be an enclosed gearbox going to the axle though, I can't remember. By the way that car pusher is awesome mr.mod, haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: new here, and would like some help... February 27th 2020, 4:12 pm | |
| so guys, if you read my reply i posted a few days ago on how bad my steering was, do you guys really think brass bushings and new heim/ball joints would fix it? but if it wont, do you guys think i should completely REBUILD my steering? like what some of you guys run on your mowers, and id probably weld it, but how much work is it? and do you guys think i could do it? and what about front suspension?
i know that it wont be easy...AT ALL, and i know it will take quite awhile. but i dont mind taking, lets say 2 weeks to complete as long as the outcome is worth it
so what do you guys think? | |
| Subject: Re: new here, and would like some help... February 27th 2020, 5:28 pm | |
| As I mentioned before, try the "Search" button and you'll find the info for steering upgrades. This topic has been covered many times. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: new here, and would like some help... March 2nd 2020, 11:04 am | |
| i just got a 6.5 horse B&S push mower engine, i am wanting to make a go kart also simiaaler to yeethaws idea, but i wanna make it out of a ladder as the frame and i have a couple ideas what i want to do for steering, and i hopefully want to find a shift on the go riding mower tranny that i can use, and ill make the clutch but I'm just wondering if there are any mods 9 engine mods ) that would go nicely with that 6.5 horse. I'm thinking a racing carburetor? anybody know of a racing carb i can put on there? and are there any internal mods you guys would recommend? | |
| | | yeethaw Member
Age : 18 Join date : 2019-04-23 Points : 2079 Posts : 182 Location : beecher il
| Subject: Re: new here, and would like some help... March 2nd 2020, 11:26 am | |
| dont know if you saw it on my thread but youll definitely need a different and heavier flywheel or a giant pulley on the bottom or else the recoil wont work right | |
| Subject: Re: new here, and would like some help... March 2nd 2020, 11:42 am | |
| what do you mean by recoil, and why do i need a heavier flywheel
btw i saw on yours that you have a plastic flywheel, i don't, i have a iron flywheel | |
| Subject: Re: new here, and would like some help... March 2nd 2020, 11:48 am | |
| Yep, push mower engines don't have big heavy flywheels because they rely on the momentum of the cutting blade spinning to get them started and stay running. Without that momentum it can be hard to get them spinning enough to start. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: new here, and would like some help... March 2nd 2020, 11:50 am | |
| oh shoot, thanks for the quick reply, but besides that, are there any mods to the engine you guys would recommend or a racing carb that you know of?
as i stated in the question above yeethaws reply, don't know if you saw it | |
| | | Double W Cross Ranch Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5306 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: new here, and would like some help... March 4th 2020, 10:17 am | |
| ik about the gov removal, but i don't know how well those will hold up, do you think i would need a different flywheel just to be safer? and I'm only 13 so i don't really know how to shave heads, but how/what do you port and polish, and idk if you saw above but i wanted to maybe get a racing carb for it, do you know of any racing carbs i could slap on there? | |
Age : 24 Join date : 2016-04-12 Points : 5773 Posts : 2623 Location : Indiana
| Subject: Re: new here, and would like some help... March 4th 2020, 11:21 am | |
| Small pit bike carb probably. The questions you’re asking, there’s no definitive answers to. Would it hold up stock? Maybe. Nobody around here that I know of really messes with them so I have no idea. For this particular subject, google might be your friend. As for porting, just look up some videos on how to do it. Not super complicated, just takes some time and patience | |
Join date : 2019-02-04 Points : 4239 Posts : 2171 Location : North Carolina
| | | | Sponsored content
