| | new here, and would like some help... | |
+10mr.modified redzz02 CraftsmanQuad19 Mister_Studabaker darkside0914 Murraymountain prancstaman AllisKidD21 MightyRaze loggers gogert 14 posters | |
prancstaman Veteran Member
| Subject: Re: new here, and would like some help... February 23rd 2020, 8:14 pm | |
| Doesn't need too much spring pressure. Maybe about 20 lbs. of pulling force on the pulley pushing or pulling on the belt to tighten it. Plus depends on what kind of springs you have handy. To much spring pull or push would just create friction but you would know this going for a test drive. Spring pressure can be adjusted by leverage on the arm that holds the pulley by having it attach before the pulley or after the pulley, in relation to the pivot point or where the arm is bolted to the frame. | |
Join date : 2019-02-04 Points : 4239 Posts : 2171 Location : North Carolina
| Subject: Re: new here, and would like some help... February 23rd 2020, 9:47 pm | |
| Yeah you need to have the right spring. Heavier than stock for sure, but don't go way overkill... Too much force and you might start burning/snapping belts (I think. Hasn't happened to me yet). | |
| | | loggers gogert Member
Age : 18 Join date : 2020-02-14 Points : 1775 Posts : 202 Location : U.S, virginia
| Subject: Re: new here, and would like some help... February 24th 2020, 10:47 am | |
| okay guys, I'm am GOING to get that 4spd you guys were talking about, but is there anything you guys would like to tell me before i get it? and also, on the description for the 4spd, it said MAX 2000rpm, soon i KNOW once i install it the internals will be going MUCH faster than 2000rpm, so that brings me to my question, is it still ok to use ? | |
| | | yeethaw Member
Age : 18 Join date : 2019-04-23 Points : 2079 Posts : 182 Location : beecher il
| | | | CraftsmanQuad19 Veteran Member
Age : 24 Join date : 2016-04-12 Points : 5773 Posts : 2623 Location : Indiana
| Subject: Re: new here, and would like some help... February 24th 2020, 12:30 pm | |
| Yes you’re still good. That’s what all of them are “rated” for. I run the 6 speed MST in one of my tractors and it has held up well | |
| Subject: Re: new here, and would like some help... February 24th 2020, 12:57 pm | |
| thank you
so yesterday i took my tractor for a ride ( first time riding it with a pulley swap ) and once i hit about 12-15 mph, the steering was like "alright imm head out" and it was just going crazy the wheels were doing this // // . \\ \\ . // // . \\ \\
and it scared the living CRAP out of me, and it was so bad it was making this noise "ttddtgtdytgdytgd" so i circled back and went to my drive way, thought it was just loose, i went to tighten up the steering, but it was already REALLY tight from when i tightened it up last time, i then got my LONGEST torque wrench and tightened it as much as i could, started it up, drove it.......and it made no difference..AT ALL
and mind you it can go MUCH faster then 15mph, i was probably at THE MOST 40% throttle.
so i guess i need better steering, I've heard rack and pinion is pretty good, but i don't know what parts i need. and i thought the other day, that bike HANDLEBAR steering would be pretty cool, any body know how id do this? i know if i were to do pike handlebar, id have to mad it to do a at the most 180 spin, instead of the 540 a regular mower does my budget for steering would be around 200-250$ and I'm probably gonna get welder, so try to include suggestions with welding in it
thanks guys can't wait to hear your suggestions! | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8401 Posts : 5190 Location : Ontario Canada
| Subject: Re: new here, and would like some help... February 24th 2020, 3:24 pm | |
| There are lots of threads on here about improving steering and front axles components, try the search bar at the top of the page and you'll find the info you need. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15110 Posts : 10664 Location : Oklahoma
| Subject: Re: new here, and would like some help... February 24th 2020, 3:30 pm | |
| Another way to search that is a little better than the site search is to go to google and enter
site:atltf.com "steering", it's what I do most of the time. There is a wealth of knowlege that many of us don't even know about! | |
| Subject: Re: new here, and would like some help... February 25th 2020, 11:09 am | |
| alright guys, so while I'm waiting for the tranny, i figured yesterday id go mess around with the mower, what did i do to it? oh, I'm glad you asked, since I'm a dumb 13 yr old kid lol, i straight piped it, and since you guys have much more experience then me, you guys probably already know what i straight piped poppy sounds like, its VERY loud, pretty much bled my ears out, so yesterday i was having a good time driving around my yard, popping wheelies, revving it like a crackhead.......what i didn't expect, was the backfiring ( he he he ) every time i setoff the throttle *POP*, and remember when i let off the throttle, it did NOT shut off. <<< remember that
okay, now this morning my dad needed me to go get some logs out of the woods, WHY, idk, so i started my mower, let it warm up for about 2 min like i always do, then i drove off, ( now before you say anything we live on 20 acres with a neighbor 1/2 mile away, so noise isn't an issue for us ) now I'm trying to go as fast as i can so i can hurry up and get inside, cause its super cold out, when i get near the woods, i let off the throttle, and since i have a foot throttle if you let off it does it quickly, and when i let off the throttle it went to idle speed, but it didn't stop at idle speed it kept going down to like 500rpm then cut off, so i then turn it back on ( starts beautifully like it always does ), and i drive off again, now since I'm in the woods, i can't drive like a bat outta hell with my booty steering. so once i come up to a turn, i let off the throttle, same thing happens again, it shut off. so i start it back up, and then i revved all the way up, and SLOWLY let off the throttle, it did NOT cut off that time. so i started to test it after that, and my final result is it shuts OFF if i let off the throttle quickly, and does NOT shut off if i let off slowly. why do you guys think its cutting off? i know you need back pressure to open the exaughst valves, but I've seen people straight pipe there mowers all the time and it dosent turn off. but why does mine turn off? i would like to keep it straight piped because i like the sound so do you guys know how i can fix this? | |
| Subject: Re: new here, and would like some help... February 25th 2020, 1:46 pm | |
| ill go see how long the pipes are in a bit
but the thing is, i put the muffler back on today and no matter what you did with the throttle it wouldn't shut down ( unless you turn it off with the key ) then just to make sure, i took the muffler back off and it shut down the way it did before | |
Join date : 2015-02-02 Points : 4910 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: new here, and would like some help... February 25th 2020, 8:13 pm | |
| You need to retune your carb, most likely running lean because you removed the muffler and the engine is moving more air through it. Running more air through an engine means you need more fuel to burn right in the cylinders. | |
| Subject: Re: new here, and would like some help... February 25th 2020, 8:21 pm | |
| ummm, ivee never really worked on mower carbs, i used to fix weedeaters and blowers though, and sell them for 30-75$ in my spare time, usuallly the issue on those was just the carb.... but ive never cleaned/fixed/adjusted a carberatour for any thing more than 3.5hp
but may i ask HOW do you adjust the carb, and where do i find the place to adjust it? | |
Age : 34 Join date : 2013-11-02 Points : 6977 Posts : 2906 Location : New Jersey USA
| Subject: Re: new here, and would like some help... February 26th 2020, 12:35 am | |
| I doubt that the running issue was caused by the exhaust pipe change, especially if it ran fine at first.
You might want to check and see if the bolts have come loose on the intake or carb causing an air leak.
Otherwise maybe some dirt got into the carb, as in some small particles were in the fuel ect. There are some mixture screws on the carb usually. On newer ones there may be only a low speed mixture screw or not any at all. The idle speed screw is on the movable part of the throttle and only for idle speed of course, not mixture. If you can post pics of the carb close up maybe we can see where the mixture screws are.
Also let us know what you tried and if anything changed ect. | |
| Subject: Re: new here, and would like some help... February 26th 2020, 12:51 am | |
| wait, isnt a staright pipe considered an exaughst leak? and no i havent changed any thing else, besides a shop vac tube i put on the carb and its now popping through the hood WHy? cause im a dumb 13 yr old kid, and it looks kinda cool
but besides that and straight pipe ( well not staright pipe any more due to the shutting off ) i havent done anything else | |
| Subject: Re: new here, and would like some help... February 26th 2020, 9:34 am | |
| - loggers gogert wrote:
- wait, so now you guys say i need to REBUILD the carb?
No, but it will help just watching those videos in the long run. If you just want to see how to adjust the carburetor, then that's what you look up on YT. | |
| Subject: Re: new here, and would like some help... February 26th 2020, 10:04 am | |
| hey guys, i found one of theses on the side of the road, needs a little work, didn't have a gas tank or battery, and recent owner didn't know what he was doing and cut the battery wires with SCISSORS to take the battery out, but i put some gas in the carb, pulled the cord and she wanted to run can these be made into DECENT mud mowers??? | |
| Subject: Re: new here, and would like some help... February 26th 2020, 10:33 am | |
| well, what i mean is, is the stock
braking good enough?
is the stock tranny good enough ( mine is chain driven ) ?
and since its chain driven ( but it has a 5 speed i think under the driver seat ) can i just do a simple sprocket swap with out the tranny self destructing?
and is the stock steering good enough? | |
| Subject: Re: new here, and would like some help... February 26th 2020, 12:08 pm | |
| If it is what you say, that’s a peerless 700, pretty stout. Can easily take a pulley swap and different sprockets. They had one weak point, it was either rpm or torque. One or the other, it’s been a long time | |
| | | | Sponsored content
