Decided to start a build on the 74 Murray gt, has 18hp opposed and 4 SPd rear, lifting it about 4in and putting 24s on it, I may regear it but not sure yet, these aren't the tires going on it it is just mocked up. Today I got the lift blocks fabbed up.
Age : 23 Join date : 2013-04-08 Points : 5001 Posts : 913 Location : Central Pa
It it lifted today, 4in in the rear, so it sits level with 24s, picking up a motor that I may use on it tomorrow if I can't get the oppy runnin', it's an 05 cub cadet kohler 20hp twin cam, still gotta fix the steering.
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4371 Posts : 467 Location : Greensburg, PA
Got the motor today, haven't got it to run yet soaking the carb overnight, the oppy has almost no compression, once again these aren't the tires I'm using, I put em on so I can roll it around.
Age : 27 Join date : 2013-03-18 Points : 7275 Posts : 3131 Location : raleigh nc
