 Extended spindles problems
Murray modder
Murray modder
Extended spindles problems Empty
PostSubject: Extended spindles problems   Extended spindles problems Icon_minitimeDecember 4th 2012, 11:12 pm
My mower just had its spindles extended (same way as FearlessFront's) But my front wheel ocainsionally (like 10 minutes or less of driving) it locks up. It just, wont spin at all. It started to ripp up the spindle, and I have no clue why. Maybe it's something in the rim? The spindle has been cleaned twice because of damage from it.
Craftsman Dude
Craftsman Dude
PostSubject: Re: Extended spindles problems   Extended spindles problems Icon_minitimeDecember 4th 2012, 11:37 pm
Are you using double nuts ? It sounds like your nut is bieng tightened by the wheel spinning, im guesing its on the right side of your tractor.
greener179
greener179
PostSubject: Re: Extended spindles problems   Extended spindles problems Icon_minitimeDecember 5th 2012, 9:59 am
make sure if you got the back rims on the front to have alot of grease in there
PostSubject: Re: Extended spindles problems   Extended spindles problems Icon_minitimeDecember 5th 2012, 12:16 pm
When i did the extended spindles on my agway, i had to cut the original washer off the back and relocate it - you want washers on both front and back of the wheel, to lock the wheel on you need two nuts locked together or a nylock nut or drill it for a pin.
It sounds like the wheel is moving around too much on the spindle and 'getting stuck' - dont over tighten the locknuts on the wheel either- it needs a lil movement.
» Kal - extended.
» extended axle HELP!
» KAL the Extended Journey.
» Theory of extended rear end for atv type swing arm to facilitate true & simple full suspension
» more F N R problems
