| Rustey Medal | |
+17MowBandit Doc Sprocket WellThatsSurprising redlinemotorsportts Murray modder mudmonkey06 richie thomas xxXMowerdudeXxx Thunderdivine Marines2621 TheRainbowBoxer Doug Chopperhed AcreFarm dangeroustoys56 CornishMorgan truckin42 21 posters |
Doc Sprocket Site VIP
| Subject: Re: Rustey Medal May 31st 2013, 7:54 pm | |
| With all that framing you're adding, surely to god you can find a slick way to relocate your fuel tank and lower the seat.
Also, I suggest finding a way to brace those exhaust pipes up before the vibrations and shocks get to them and end up cracking your cylinder heads... | |
greener179 Member
| Subject: Re: Rustey Medal May 31st 2013, 8:32 pm | |
| To have more room between the rear rims and the roll cage i would cut the stock rim down some | |
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5294 Posts : 1070
| Subject: Re: Rustey Medal May 31st 2013, 9:26 pm | |
| - Doc Sprocket wrote:
- With all that framing you're adding, surely to god you can find a slick way to relocate your fuel tank and lower the seat.
Also, I suggest finding a way to brace those exhaust pipes up before the vibrations and shocks get to them and end up cracking your cylinder heads... Also i plan on lowering the seat as soon as i get a new gas tank so i can relocate it and that way i can build the top part of the cage without it being so high. Also the stacks do have supports. | |
| Subject: Re: Rustey Medal May 31st 2013, 9:27 pm | |
| - greener179 wrote:
- To have more room between the rear rims and the roll cage i would cut the stock rim down some
Yeah i plan on cutting them down here soon. | |
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: Rustey Medal May 31st 2013, 9:40 pm | |
| - truckin42 wrote:
Also the stacks do have supports. Oh, good. I can't see them. | |
| Subject: Re: Rustey Medal May 31st 2013, 9:47 pm | |
- truckin42 wrote:
Also the stacks do have supports. Oh, good. I can't see them. Yeah they blend in with the stacks. | |
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
| Subject: Re: Rustey Medal June 1st 2013, 11:00 am | |
| When you are done are you going to put anything tractor related back on it (fenders, hood,etc..)? | |
| Subject: Re: Rustey Medal June 1st 2013, 10:20 pm | |
| I plan on making an full engine cage for a hood. As for tractor related parts none of the origanal part will go back on it mabe a set of trailer fenders. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: Rustey Medal June 1st 2013, 10:22 pm | |
| i dont know if they still have them, but bmi carts had 10" wide aluminum diamond plate fenders for 29.99 on sale | |
| Subject: Re: Rustey Medal June 1st 2013, 10:24 pm | |
| Well i need steel ones so i can weld them on the cage. But ill check them out. | |
| Subject: Re: Rustey Medal June 2nd 2013, 7:35 am | |
| The aluminum tread plate stuff would look good, but they would be harder to mount. Besides that, most of the BMI stuff is geared towards karts an minibikes- designed to go over tires that are only 15" or 16" in diameter. Put a wee little fender like that over a fullsize car tire, it's gonna look dumb.
I say go with the steel trailer fenders. Cheap, made for larger tires, weldable, etc. Then again, that's exactly what I did... LOL | |
| Subject: Re: Rustey Medal June 2nd 2013, 9:25 am | |
| Yeah i gonna go with the trailer fenders. | |
| Subject: Re: Rustey Medal June 5th 2013, 10:25 am | |
| Well guys i took rustey out for a romp and desided to make a new trail well the hill was alittle to steep and had alot of loss dirt on it so i went around the woods and my mower was just about out of gas so i floored it and put the lever all the way fowerd and just went for it and just runnin over all diffrent sizes of logs ran over alot of desint size branches it did spin but i just wiggled the mower and it went over it i did have to get off it once and pick it up over a log the was like 10" wide but overall nothin broke and it handeled it prety good spun alittle but it got thru it. | |
| Subject: Re: Rustey Medal June 5th 2013, 11:25 pm | |
| Today i was thinkin should i change my tires from the 24" car tires to the 33" truck tires you guys tell me should i? | |
| Subject: Re: Rustey Medal June 5th 2013, 11:31 pm | |
| i say do it, but if you do, you should mount your current rear tires on the front to keep it from sitin down to low in the front | |
| Subject: Re: Rustey Medal June 6th 2013, 10:16 am | |
| Do the hub thing I did in the rear haha | |
| Subject: Re: Rustey Medal June 6th 2013, 10:33 pm | |
| Well that is what i was gonna do but my roll cage will be in the way. | |
| Subject: Re: Rustey Medal June 6th 2013, 10:38 pm | |
| - truckin42 wrote:
- Well that is what i was gonna do but my roll cage will be in the way.
Oh that's right. Maybe cut that other side of the Ron off like the one towards the seat? I'd look cleaner | |
| Subject: Re: Rustey Medal July 15th 2013, 10:01 pm | |
| Hey guys i know i havet been keeping you guys update and thats becaues iv been real busy with work and havent had a whole lot of time to work on rustey or to come on here and hangout alittle bit.
Im hoping to be able to work on rustey and log on here when school starts again but if i can log on i will. | |
1997 Murray Veteran Member
| Subject: Rustey Medal December 13th 2013, 7:53 pm | |
| anything going on with this? it looks interesting. | |
| Subject: Re: Rustey Medal December 14th 2013, 8:25 pm | |
| Yeah I plan on rebuild it here soon. | |
| Rustey Medal | |
