| The Marshmaster John Deere | |
+6Craftsman Dude Doc Sprocket cumminsbayou crazykid1994 redlinemotorsportts k2500life 10 posters |
k2500life Veteran Member
Age : 26 Join date : 2013-06-19 Points : 5162 Posts : 1135 Location : Southern Florida
| Subject: The Marshmaster John Deere October 4th 2013, 9:00 pm | |
Last edited by Doc Sprocket on October 5th 2013, 9:14 pm; edited 1 time in total (Reason for editing : Re-titled at OP's request) | |
Guest Guest
Age : 29 Join date : 2013-03-18 Points : 4716 Posts : 618 Location : loxahatchee, florida
| Subject: Re: The Marshmaster John Deere October 5th 2013, 3:31 pm | |
| Carb issues probably float might get stuck open. Id say buy a new carb or rebuild it | |
cumminsbayou Member
Age : 26 Join date : 2011-11-04 Points : 4812 Posts : 232 Location : fairhope Al.
| Subject: Re: The Marshmaster John Deere October 5th 2013, 6:56 pm | |
| May be something to do with the fuel pump? I know most of the new john deeres have the gas tanks in the back. Try just putting a shut off on it for when its not running if it isn't a carb issue. I'd check the fuel pump lines also make sure there clean and hooked up right. | |
| Subject: Re: The Marshmaster John Deere October 5th 2013, 7:08 pm | |
| The carb will still limit the fuel pump. when its full the carb closes so it can't pump in. Try cleaning the carb thoroughly and make sure the float closes the needle to stop fuel going in. | |
| Subject: Re: The Marshmaster John Deere October 5th 2013, 7:37 pm | |
| The problem is that when I take the Line off it runs good but ad soon as I Put it on it runs off and on. And I did clean it | |
| Subject: Re: The Marshmaster John Deere October 5th 2013, 8:33 pm | |
| Alright still no resolution of the fuel issue but I added some upgrades Also can some change the name of this build to THE MARSHMASTER John deere Before After said upgrade Rear view After said mud After said mud rear view | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7109 Posts : 2914 Location : Ontario Canada
| Subject: Re: The Marshmaster John Deere October 6th 2013, 8:39 am | |
| If you're still flooding out, get into that carb. The fuel pump is not all of a sudden pumping more than it ever did. The carb is supposed to regulate fuel flow. If it's flooding, the fuel inlet system is not working properly. This consists of the float and fuel inlet valve. When the carb gets low on fuel, the float drops opening the fuel inlet valve and lets more fuel into the fuel bowl. As the bowl fills, the float rises, forcing the fuel inlet needle into it's seat, cutting off fuel delivery so it won't flood.
The most common cause of flooding like yours, is debris on the needle or seat, causing a failure to seal when the float rises. Clean the needle and seat thoroughly but be careful not to damage them. The needle or seat could be damaged, the float might no longer float properly (hole in it, letting fuel in) or the float height may not be set correctly. | |
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4403 Posts : 145 Location : MS
| Subject: Re: The Marshmaster John Deere October 6th 2013, 9:39 am | |
| Some of the newer briggs carbs the entire bottom of the carb is plastic and it separates from the rest when you remove the bowl and it has an o ring and o ring gasket between the them if one of those is bad it would cause your problem .I fixed one last year doing the same thing it was just a bad o ring .
Join date : 2013-06-01 Points : 4601 Posts : 578 Location : West Virginia
| Subject: Re: The Marshmaster John Deere October 6th 2013, 11:15 am | |
| Make sure our bowl is no bent down..piny did that to me so I just bet is back up so it would close the needle sooner.. | |
| Subject: Re: The Marshmaster John Deere October 6th 2013, 1:04 pm | |
| I swapped in a medal needle. Didn't work because it didn't slide right. So make sure it is the exact size and diameter if you do. I did find one that matched just so you know | |
| Subject: Re: The Marshmaster John Deere October 7th 2013, 6:46 pm | |
| Cleaned out the carb did time and it ran good for like 3 min then started surging I don't believe that it is flooding any more but ran it around for Like 10 min and it stalled and wouldn't start again. Stalled right here New tires for the front | |
| Subject: Re: The Marshmaster John Deere October 8th 2013, 8:27 am | |
| Got the new tires mounted up and I will install them after school! Also I'll get pics after school | |
cumminsbayou Member
| Subject: Re: The Marshmaster John Deere October 8th 2013, 8:52 am | |
| Have you messed with the fuel pump? I'd make sure none of the hoses going to it aren't pinched and make sure is pump fuel when you turn it over. | |
