got my engine running right again.... turns out my snorkel was tweaked just enough that it was pushing on my gasket to the carb and causing it to suck air in behind the carb. so i need a new rubber gasket and i already tweaked my snorkel to work right
motorizedeverything Member
Age : 26 Join date : 2013-01-02 Points : 4492 Posts : 356
got my setup working. goes around 20mph in 5th gear 20" tires. still plan on dropping back to 18". blew out one of my moded turfs will in 5th. haha wish i had a video of riding it home....
Age : 29 Join date : 2013-03-18 Points : 4716 Posts : 618 Location : loxahatchee, florida
got my mower almost 100% finished. just need to take my bumper from the other frame and mount it. got my tires switched back to good rims so i could use them. and i need an air filter to fit my snorkel. rides like a charm and exactly how i want it to feel. just need beefier front tires too
if i can make enough money and nobody buys this in the next month ill buy a new v pulley for my clutch and take a camera i have in a plastic bag and video me mudding on it
finally ordered tire tubes.... and looking for a place to buy new idler pulleys. will light duty work for high speed? idk what to get. i need 2 of them 3" od with 1/2" bore. 1 is v and one flat for a murray clutch
tire tubes came in and so did my new main jet. oddly enough it has a bigger hole than the old one but my mower is running like a charm and idles and revs again. one tube leaks from around the valve stem. probably my fault when i put it in. the other is nice and holds air. will probably buy another tube again. at least it will be easier to put in this time now. just gunna buy a new idler pulley for it. and than mud!!!!!!!!!!!!!!!
this is just a quick walk around again after i got everything together
might be saying goodbye to it tonight. someone is coming to look at it and possibly buy it. i need the money for car tires and that leads the way to save for my buggy project
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
well thats if they wanna buy it. i still have a project on the backburner that will kill this thing. i did take it out for a final spin tho. wish i had a waterproof camera cuz i took it mudding a little.
