| | Twin cyl EFI conversion kit!?!? (400cc-800cc) | |
+3Moose willis923 redlinemotorsportts 7 posters | Author | Message |
Age : 27 Join date : 2013-03-18 Points : 7275 Posts : 3131 Location : raleigh nc
Age : 27 Join date : 2013-04-10 Points : 5553 Posts : 1408 Location : Galway NY
| | | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4743 Posts : 919 Location : Defiance, Ohio
| | | | Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6335 Posts : 2101 Location : Norway, Europe
| Subject: Re: Twin cyl EFI conversion kit!?!? (400cc-800cc) May 15th 2014, 5:04 am | |
| It's cool and all that, but i bet you get alot of trouble starting and tuning that you would never get before. So I'd say why bother, rather get a bigger cc engine if anything. | |
| | | Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7110 Posts : 2914 Location : Ontario Canada
| Subject: Re: Twin cyl EFI conversion kit!?!? (400cc-800cc) May 15th 2014, 5:59 am | |
| Throttle response would improve, and you MIGHT get a wee bit more power due to better fuel atomization. Possible better economy, too- although I wouldn't consider that to me much of a concern for these things either.
Now, in the world of offroading (rockcrawling, trails, etc) EFI offers the benefit of being able to operate at angles that would flood or starve a carb. For the most part, I've found that our carbs can continue to operate at sufficient angles to leave the rider on the ground anyways, though... LOL
All in all, I wouldn't bother. Besides... Ain't nothing like trying to troubleshoot a bitchy EFI system, especially out on the trail. A carb, I can usually sort out in minutes... | |
| Subject: Re: Twin cyl EFI conversion kit!?!? (400cc-800cc) May 15th 2014, 8:56 am | |
| I thought it was neat, little over complicated but I was looking at it as a speed mower or racing mower setup because its probably not water resistant. I wonder if it would work better as a direct injection fuel injector instead of bug spraying it like they are now. | |
| | | RCG Member
2016 Build-Off Finalist
| Subject: Re: Twin cyl EFI conversion kit!?!? (400cc-800cc) May 15th 2014, 9:31 am | |
| I have personally talked with the maker of these kits in the past and if you look them up on youtube he has a channel. He has not bothered to look into lawn tractors much because of low demand and the fact that Honda has brought them out on the market twice and it flopped. He said he would be more then willing to help me customize one but to plan on 100.00 in extras to make it work. | |
| | | B440 Member
Join date : 2014-01-22 Points : 3996 Posts : 226 Location : Thompson, CT
| Subject: Re: Twin cyl EFI conversion kit!?!? (400cc-800cc) May 15th 2014, 10:18 am | |
| Fuel injection works best at rpms in between idle and wot. You won't get much of a power gain.
I like these tractors because of the simplicity.
I've seen ecotrons a few years ago when I was looking for efi on a CR500 dirtbike. In the end, simplicity of the carb won me over. | |
| Who is online? | In total there are 36 users online :: 0 Registered, 0 Hidden and 36 Guests
