| Richie's lifted 4x6 IH cub 782 GT "mini deuce" | |
+19mr.modified willis923 the craftsman mudder Doug B440 LAWN MOWER MUDDER Moose k2500life 1997 Murray mrkadage Lawren Wimberly dked41 Doc Sprocket redlinemotorsportts Thunderdivine TheRainbowBoxer TroyBilt Pony camomanusa richie thomas 23 posters |
Moose Established Member
B440 Member
Join date : 2014-01-22 Points : 3995 Posts : 226 Location : Thompson, CT
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" February 12th 2014, 10:17 am | |
| I like your project. I've thought about dual axles, but I can't decide on locked or unlocked diffs. It's going to be very hard to turn with two locked diffs on a longer frame. It would be cool to see open diffs and two pedals to control left and right rear brakes. Those would help steer the machine better. | |
Age : 35 Join date : 2014-01-12 Points : 4742 Posts : 919 Location : Defiance, Ohio
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" February 12th 2014, 10:26 am | |
| - B440 wrote:
- I like your project. I've thought about dual axles, but I can't decide on locked or unlocked diffs. It's going to be very hard to turn with two locked diffs on a longer frame. It would be cool to see open diffs and two pedals to control left and right rear brakes. Those would help steer the machine better.
or just make the front axle a live axle so it pulls the buggy doubt double brakes would be a good idea accidentally hit one at high speed annnnnnnd.... ever heard that song wipeout? yeah... | |
Age : 57 Join date : 2013-12-21 Points : 4596 Posts : 744 Location : Salem Illinois
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" February 12th 2014, 10:32 am | |
| B440, I've thought the same thing. In fact, since The Red Fox's rear has 2 mechanical drum brakes, I'm leaving the diff open and making a split brake pedal so I can control which tire gets the torque in mud. Red Fox doesn't have the dual axles like richies mini deuce, but it will be nearly as big. The longer wheelbase of these bigger builds as well as the extra weight should make turning easier than on the smaller ones. The smaller rigs tend to shift the weight rearward when under power, which makes the front end "Float" and get little traction for steering. It's kinda like trying to steer while doin a wheelie. | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4370 Posts : 467 Location : Greensburg, PA
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" February 12th 2014, 3:44 pm | |
| - Lawren Wimberly wrote:
- B440, I've thought the same thing. In fact, since The Red Fox's rear has 2 mechanical drum brakes, I'm leaving the diff open and making a split brake pedal so I can control which tire gets the torque in mud. Red Fox doesn't have the dual axles like richies mini deuce, but it will be nearly as big. The longer wheelbase of these bigger builds as well as the extra weight should make turning easier than on the smaller ones. The smaller rigs tend to shift the weight rearward when under power, which makes the front end "Float" and get little traction for steering. It's kinda like trying to steer while doin a wheelie.
i never thought of that, thats an interesting thing to see or try myself. | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6191 Posts : 1434 Location : east dublin georgia
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" February 12th 2014, 7:17 pm | |
tis easier than doing that lawren.........lol i start work friday, so ill be getting payed next week, ill buy some steel and such so when i get a day off i can work on it | |
Doug Site Owner
Age : 28 Join date : 2012-12-24 Points : 7560 Posts : 3035 Location : Lebanon County, PA
the craftsman mudder New Member
Age : 25 Join date : 2014-01-13 Points : 3778 Posts : 20 Location : North Carolina
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" March 2nd 2014, 10:22 pm | |
| figured i would make a list of parts i need to buy,borrow, make so here is goes 1 mst-206 tranny 2. 2 12" gt 5 lug rims 3. 4 27" tires 3. 2 2" long shaft couplers 4. 3 6" pulleys with 5/8" bore 5. 1 6" pulley with 1" bore 6. belts 7. 2' of 5/8" keyed shaft 8. 3-4 sticks of 1" sqr. tubing 9. 1 stick of 4" wide 3/16" steel 10. 1 stick of 1/8" wall 1" tubing 11. welding wire. 12. 1 4'x8' sheet of 16 ga steel and some stuff i might get for it if i have money 1. 3500 lb winch 2. on board air 3.c.b. antanae
Join date : 2013-06-01 Points : 4601 Posts : 578 Location : West Virginia
willis923 Veteran Member
Age : 27 Join date : 2013-04-10 Points : 5552 Posts : 1408 Location : Galway NY
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" March 3rd 2014, 9:28 pm | |
| well guys, i got some pics, not many, but some is better than nothin and if you dont believe that, ask a scuba diver thats either a 78, or a 88 quart cooler, i cant remember which | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" March 3rd 2014, 9:38 pm | |
| I see you made the bumper sorta like the old chevy i showed you! looks great! The only thing i would have done, was weld the bumper onto some brackets and mounted it on the frame. The way a tail gate could be installed if need be. | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" March 3rd 2014, 9:48 pm | |
| - TroyBilt Pony wrote:
- I see you made the bumper sorta like the old chevy i showed you! looks great!
The only thing i would have done, was weld the bumper onto some brackets and mounted it on the frame. The way a tail gate could be installed if need be. lol i just have it sitting there for a mock up tbp, its going to be bolted to the frame | |
| Subject: Re: Richie's lifted 4x6 IH cub 782 GT "mini deuce" March 3rd 2014, 10:10 pm | |
The only thing i would have done, was weld the bumper onto some brackets and mounted it on the frame. The way a tail gate could be installed if need be. lol i just have it sitting there for a mock up tbp, its going to be bolted to the frame I seen white and shiny spots and assumed flux welded together lol | |
