 swamp donkey is getting an upgrade
swamp donkey is getting an upgrade Empty
PostSubject: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeSeptember 11th 2011, 6:58 pm
Pulled the hydro and 10hp subaru.
putting in a 6 speed out of a SS16 and the 20hp kohler out of the walker.
the old axle extensions should slip on the new TX, just need to get 1 hub off.
got the sticky b!tch in traction right now. dont want to get out the torch, but I might have to
swamp donkey is getting an upgrade IMG00066
PostSubject: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 12th 2011, 6:24 pm
got the front hubs made and put on. moved the shock mounts. waiting on steering parts
swamp donkey is getting an upgrade Photo_032511_001
F150F250F350
F150F250F350
PostSubject: ???   swamp donkey is getting an upgrade Icon_minitimeOctober 13th 2011, 3:03 pm
Do you have a you tube chanel or were can I see this thing in action?
PostSubject: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 13th 2011, 4:40 pm
Nope .... This is about as hi-tec as I get.
Ropertractor14
Ropertractor14
PostSubject: Re: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 13th 2011, 7:06 pm
The ss16 transmission is the 3speed +high, low ?
https://www.youtube.com/user/GMCsierra1500
PostSubject: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 13th 2011, 8:02 pm
yep. using the sears steering too. good and tight with a high ratio, it should steer pretty good.
Need 1 more good day to finish the steering , then on to the clutch and shifters
Fattypipemuarry
Fattypipemuarry
PostSubject: Re: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 14th 2011, 11:52 am
is you welder a 140 hobart
PostSubject: swamp donkey is getting an upgrade   swamp donkey is getting an upgrade Icon_minitimeOctober 14th 2011, 2:47 pm
yep. went with the bigger liner when I had to replace it. .035 feeds alot better now
» The Swamp Rat
» Lil Donkey 2 UK Ratty hybrid SLAMMED -progress 9-5-18
» 2002 Murray "Swamp Pro"
» Dynamark Upgrade.
» Mini Swamp/Platform Buggie
