| My new trail machine- 1993 Craftsman II | |
1997 Murray Veteran Member
| Subject: Re: My new trail machine- 1993 Craftsman II November 26th 2014, 4:16 pm | |
| I need some pics on what to do with a craftsman. I decided not to do 4x4, and I have a mst 206 and a peerless 2300A 4 speed that i could use. what should I do with it? make a utility thing or something else? | |
ZSmachines Member
Age : 24 Join date : 2014-08-27 Points : 3783 Posts : 221 Location : PNW
| Subject: Re: My new trail machine- 1993 Craftsman II November 26th 2014, 6:07 pm | |
| I would make this into a utility, and rebuild the aws tractor, and make that into an awesome off roader it should work good as your rear tires can move and get better traction | |
| Subject: Re: My new trail machine- 1993 Craftsman II December 8th 2014, 11:10 am | |
| ok so I am going to speed up the tractor like the mowercycle gang did on their 930. and here is a paint picture I am working on: it will have duro mud and sand 22x11x8s on it. | |
ZSmachines Member
ZSmachines Member
muddstir Member
Join date : 2012-01-22 Points : 4828 Posts : 318 Location : Western,PA
| Subject: Re: My new trail machine- 1993 Craftsman II December 11th 2014, 2:35 pm | |
| - 1997 Murray wrote:
- I decided not to do 4x4
Woah woah woah, you should send me the AWS then... hazardous material. I'm certified to dispose of it properly.... | |
ZSmachines Member
| Subject: Re: My new trail machine- 1993 Craftsman II December 12th 2014, 3:00 pm | |
| got to drill and tap the case for brakes, the original bolts snapped off. got the rear tires mounted on hubs, and remouved the safety swiches. | |
ZSmachines Member
ZSmachines Member
| Subject: Re: My new trail machine- 1993 Craftsman II December 16th 2014, 1:34 pm | |
| anyone have a good place to get shift keys? I need them, mine are shot. it would run and drive now but the shift keys are holding me up. I am trading zsmachines for a different set of fenders and some more stuff. | |
| Subject: Re: My new trail machine- 1993 Craftsman II December 22nd 2014, 10:44 am | |
| got an mst in this, pulley swapped, and got shifter and other things hooked up. rode it, belt stays on, looks good, and it goes 45 mph. now for bumper and winch!
| Subject: Re: My new trail machine- 1993 Craftsman II January 19th 2015, 1:22 pm | |
| Well I decided this will be my build off machine, and I took the mst and opposed out, and I am going to rebuild it with a onan opposed and peerless 1200 tranny, and it will need completely redone to work with the horizontal shaft stuff. It will be a utility/puller, with a top speed of 10 mph. I am also redoing the steering since my craftsman stuff stripped out. Plans are 26" ag tires on the rear, and those 20" in the picture. I will essentially be making a gt out of an lt. so this is all I have now: the motor is just sitting there, not mounted yet, obviously. | |
| Subject: Re: My new trail machine- 1993 Craftsman II January 19th 2015, 7:24 pm | |
| Oh my goodness for myself. This thing is about to get a hole lot better. Probable what I'd do if I had to make another off-roader. Can stick some nasty tires on there. | |
