| 1990 Craftsman II - Trail Rig | |
+3Creepycrawler AllisKidD21 steelheadben 7 posters |
steelheadben New Member
| Subject: 1990 Craftsman II - Trail Rig October 20th 2019, 6:12 pm | |
| To start this thread, I picked up this mower locally for $100. Super clean machine. It has a 12hp Briggs engine with a Peerless 930-011 transaxle. Ran well, everything worked as should. (Including the headlights.. bonus!) The next weekend, I was able to buy a locked mst-205 transaxle from a friend of mine for a good deal. has brand new carlisle tires on it as well as a 4.5 inch pulley already on it. the old transaxle was removed and I installed the new one in. installation was easy, no issues at all! in this image, I was in the process of removing the old transaxle. in this image, the new transaxle (mst-205) is on the right, while the stock 930-011 transaxle is on the left. in this image, the shift linkage was a direct fit once the shifter plate was swapped with the old one. no customization needed! | |
Age : 25 Join date : 2016-07-10 Points : 8390 Posts : 5190 Location : Ontario Canada
| Subject: Re: 1990 Craftsman II - Trail Rig October 20th 2019, 9:00 pm | |
| Nice! Glad the trans swap worked out for you! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 36 Join date : 2013-07-02 Points : 4822 Posts : 731 Location : Logan Ohio
Age : 23 Join date : 2016-04-12 Points : 5762 Posts : 2623 Location : Indiana
| Subject: Re: 1990 Craftsman II - Trail Rig October 20th 2019, 11:45 pm | |
| 6 might be a bit on the wild side, and will have clutch fitment issues. I think the biggest you can go with the stock clutch is 4.5, but I’ll have to double check on mine | |
| Subject: Re: 1990 Craftsman II - Trail Rig October 20th 2019, 11:51 pm | |
| Oh never mind, I must be more tired than I realize. But you actually have a Murray based tractor, not the noma/dynamark based tractor I was thinking.
So I believe your clutch is in the rear right? | |
Age : 21 Join date : 2016-10-29 Points : 6627 Posts : 3643 Location : Lewisburg, KY
| Subject: Re: 1990 Craftsman II - Trail Rig October 21st 2019, 12:52 am | |
| Like CC said, a 6" pulley on the front would get this thing moving, as well as an idler to help belt tension. Nice rig. | |
| Subject: Re: 1990 Craftsman II - Trail Rig October 21st 2019, 4:53 pm | |
| - CraftsmanQuad19 wrote:
- Oh never mind, I must be more tired than I realize. But you actually have a Murray based tractor, not the noma/dynamark based tractor I was thinking.
So I believe your clutch is in the rear right? correct, clutch is in the rear just above the transaxle. Only issue I had before packing up for the day was clearance for the belt around the shifter. it is super close but I won't know until the new belt is installed. | |
Age : 34 Join date : 2013-11-02 Points : 6966 Posts : 2906 Location : New Jersey USA
| Subject: Re: 1990 Craftsman II - Trail Rig October 22nd 2019, 12:06 am | |
| Craftstman quad a buddy had a twin to this one, thats why I said it, that was the nice thing about when we would run a murray based tractor, clutches seemed to slip less than the front clutch tractors as well. | |
| Subject: Re: 1990 Craftsman II - Trail Rig October 22nd 2019, 5:07 pm | |
| UPDATE 10/22/2019
I've had no time yet to get more progress done, however I returned the 4.5 pulley for the motor and i'm going to get a 6 inch instead. New belt is on the way too. | |
| Subject: Re: 1990 Craftsman II - Trail Rig October 27th 2019, 3:57 pm | |
| It moves!! added the 6 inch engine pulley and a new 93 inch belt. also finished installing a new flo jet carburetor and a gas pedal. it runs and moves okay... 5th is crazy fast!
also.. trying to locate an intake elbow for a 12hp flathead briggs. I currently have the one piece flo jet carburetor and I cant get it to tune right. I have a mikuni 26mm that i'd like to put on it, so I need this elbow to do so. if anyone has a spare that they'd ship to zip 16509 cheap, im paypal ready to pay. | |
muddstir Member
Join date : 2012-01-22 Points : 4840 Posts : 318 Location : Western,PA
| Subject: Re: 1990 Craftsman II - Trail Rig October 27th 2019, 7:23 pm | |
| That's a nice looking machine you got there.
I may have that intake you need but I'll have to check some of my spare parts engines to make sure. I'll let you know. | |
| Subject: Re: 1990 Craftsman II - Trail Rig October 27th 2019, 8:41 pm | |
| - muddstir wrote:
- That's a nice looking machine you got there.
I may have that intake you need but I'll have to check some of my spare parts engines to make sure. I'll let you know. Sounds good! Let me know. | |
