| torque converte sideways | |
+6GenevaCustoms 802 Customs Thunderdivine Carshowkid Doc Sprocket N1ck 10 posters |
N1ck Member
Age : 23 Join date : 2014-06-08 Points : 3695 Posts : 74 Location : North Central Arkansas
| Subject: torque converte sideways February 8th 2015, 8:58 pm | |
| I have been wondering if anyone has done it and if it would work | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7110 Posts : 2914 Location : Ontario Canada
| Subject: Re: torque converte sideways February 9th 2015, 8:30 am | |
| I have not done it, but I've thought about it. From everything I can tell, it will function just fine.
I am assuming you want to use it on a vertical shaft engine, like a lawn tractor. My only concern there, is it hanging low, under the belly of the beast, as it were. CVT's aren't happy when sand or mud get up inside. | |
Carshowkid Member
Age : 24 Join date : 2014-07-22 Points : 3963 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: torque converte sideways February 9th 2015, 10:40 am | |
| If you have a skid plate... The worst that can get in is a tiny bit of mud... But mostly sand and water | |
| Subject: Re: torque converte sideways February 9th 2015, 12:52 pm | |
| The problem with skid plates and other shields is that while they can HELP keep crap out, they can also help trap crap in. Food for thought. | |
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6335 Posts : 2101 Location : Norway, Europe
| Subject: Re: torque converte sideways February 9th 2015, 2:24 pm | |
| - Doc Sprocket wrote:
- The problem with skid plates and other shields is that while they can HELP keep crap out, they can also help trap crap in. Food for thought.
That's a very valid point, I learned long ago also on waterproofing stuff. If you can't get it 110% waterproof, then don't waterproof it at all. Just let it rince off and air dry again. | |
Carshowkid Member
N1ck Member
| Subject: Re: torque converte sideways February 9th 2015, 5:43 pm | |
| thanks every body and yes Doc i do want to use it on a vertical shaft engine | |
N1ck Member
| Subject: Re: torque converte sideways February 9th 2015, 8:15 pm | |
| Also does anyone know of a comet CUT that can withstand up to 20 horsepower | |
N1ck Member
| Subject: Re: torque converte sideways February 9th 2015, 8:51 pm | |
| The Comet 40 is factory rated to 18hp. However, I have NO doubt it will handle 20. I rant the HELL out of a 40 for years. Bulletproof. | |
Carshowkid Member
| Subject: Re: torque converte sideways February 9th 2015, 8:52 pm | |
- The Comet 40 is factory rated to 18hp. However, I have NO doubt it will handle 20. I rant the HELL out of a 40 for years. Bulletproof.
but then I have a 6hp stock with a. Really good tune and burn one up in a summer...but that was with a comet clutch | |
802 Customs Member
Age : 24 Join date : 2015-01-08 Points : 3550 Posts : 146 Location : Vermont
| Subject: Re: torque converte sideways February 10th 2015, 12:37 am | |
- CVT's aren't happy when sand or mud get up inside.
What about ATVs? I know some newer "automatic" ATVs are just a cvt with mechanical reverse gear, and usually high and low range to choose between. Some guys absolutely bury their ATV in mud. | |
| Subject: Re: torque converte sideways February 10th 2015, 7:30 am | |
What about ATVs? I know some newer "automatic" ATVs are just a cvt with mechanical reverse gear, and usually high and low range to choose between. Some guys absolutely bury their ATV in mud. I had an ATV like that. Never fully sunk it. I CAN tell you the CVT was quite well protected though. If it DID get full of schmutz, it WOULD be a problem. Simple mechanics. | |
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4207 Posts : 315 Location : Florida
| Subject: Re: torque converte sideways February 10th 2015, 8:40 am | |
What about ATVs? I know some newer "automatic" ATVs are just a cvt with mechanical reverse gear, and usually high and low range to choose between. Some guys absolutely bury their ATV in mud. Yea the atvs normally have a cover that goes over it with a gasket, drain plug on bottom and a "snorkel" that runs to the bottom of the airbox for vent and cooling that's on a few I've seen. | |
| Subject: Re: torque converte sideways February 10th 2015, 8:50 am | |
| That's exactly how mine was laid out. Was a late '90's Kawi Prairie 400 4x4. | |
N1ck Member
| Subject: Re: torque converte sideways February 11th 2015, 3:42 pm | |
| thanks everybody i will probably use a comet 44 magnum setup. no it will be the 40
Last edited by N1ck on February 15th 2015, 4:15 pm; edited 1 time in total (Reason for editing : new info) | |
N1ck Member
| Subject: Re: torque converte sideways February 15th 2015, 8:56 am | |
| So far as I recall (been awhile) it's just a matter of pulley diameter, so it affects the final drive ratio a bit. I have a 40 setup, never had a 44. | |
N1ck Member
Age : 27 Join date : 2012-10-31 Points : 4956 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: torque converte sideways February 15th 2015, 2:14 pm | |
| Hey N1ck, I'm just done reading this and I think a 40 would be best for this since people have used them more. And thanks for being part of the trip, the more the marrier!!! | |
N1ck Member
deaddave New Member
Age : 72 Join date : 2015-05-04 Points : 3297 Posts : 13 Location : Greensburg Indiana
| Subject: Re: torque converte sideways January 25th 2016, 2:17 pm | |
| I know this probably dumb but, could the cvt be placed above in the tunnel area via short vertical jack shaft? It would keep it protected somewhat . | |
N1ck Member
STUNTMAN JON Member
Age : 39 Join date : 2016-01-22 Points : 3126 Posts : 100 Location : Belfast Northern Ireland
| Subject: Re: torque converte sideways January 25th 2016, 5:14 pm | |
| Had been toying with this idea too, but as Doc says the driver will hang low below the engine, for a 44 its about 5.5 - 6 inches, so a decent bit below your frame rails, then the mechanism of the driven pulley is also in the way as it protrudes the opposite way to the driver. i messed about with a bunch of different designs to accommodate it on a vertical shaft setup, pretty much all would involve a jackshaft setup, it could be done ok especially if you had a tractor with a tunnel type body as Dave says. keeping it accessible for maintenance would be key in executing it well too. did you want to ditch the transaxle and run a 90 degree box and a go kart axle?
in the end i opted out of the idea of using it as i wanted to bring the engine as far back towards the driver as possible, so there was no room for the cvt. whats your application? | |
N1ck Member
| Subject: Re: torque converte sideways January 29th 2016, 2:40 pm | |
| I was thinking of running a cvt to a transaxle for a street build but it got shot down | |
