| lifted atv craftsman aka marshen | |
+5redlinemotorsportts craftsmancole LAWN MOWER MUDDER 1997 Murray kawasaki220 9 posters |
Age : 23 Join date : 2014-01-22 Points : 4362 Posts : 546 Location : north carolina
1997 Murray Veteran Member
Age : 23 Join date : 2013-04-08 Points : 5000 Posts : 913 Location : Central Pa
| Subject: Re: lifted atv craftsman aka marshen June 12th 2014, 3:50 pm | |
| Not to be mean but I hate when people put directional tires on the wrong way. (the front ones) IT DRIVES ME INSANE!
Other than that it looks pretty cool. | |
Age : 24 Join date : 2013-04-05 Points : 4753 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: lifted atv craftsman aka marshen June 12th 2014, 4:05 pm | |
| - LAWN MOWER MUDDER wrote:
- Not to be mean but I hate when people put directional tires on the wrong way. (the front ones)
IT DRIVES ME INSANE! I agree, they're made to spin one way to clean out, if you put them on backwards then they dont clean out as good and it looks wrong. | |
| Subject: Re: lifted atv craftsman aka marshen June 12th 2014, 4:59 pm | |
| Cut the holt front frame off that atv and that will make your life so much easier. mod it to the frame, and it gives you the correct steering, and shock positions | |
CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4027 Posts : 337 Location : Woodville Al
| Subject: Re: lifted atv craftsman aka marshen June 12th 2014, 7:24 pm | |
Other than that it looks I agree. I thought ofdoing the same thing but decided to do 4 link. | |
rarbaugh07 Member
Age : 35 Join date : 2014-01-22 Points : 3868 Posts : 117 Location : Logan, iowa
| Subject: Re: lifted atv craftsman aka marshen June 13th 2014, 10:26 am | |
| - rarbaugh07 wrote:
- Since the front tires are being pushed wouldn't it be better to have backwards.
But they wouldn't clean themselves out the right way. It still just doesn't look right. | |
| Subject: Re: lifted atv craftsman aka marshen June 13th 2014, 10:35 am | |
| i sorry the hole front shocks and everything are on the wrong side ,it was just a mock up, the tires are not on backwards just on the wrong side | |
CornShuck4CE Member
| Subject: Re: lifted atv craftsman aka marshen June 13th 2014, 12:40 pm | |
| As far as cleaning themselfs out. No tire will clean itself if it dont have any rotational momentum go thru thick mud slow not spining and they will cake up. Go thru mud slow and spinning and front tires will cake up and rear will clean out if you turn them fast enough. The fronts going to cake up eather way only way they going to clean out is going fast or it just falling out as you ride the trail. Noce build lookin forward to seeing it come along. | |
| Subject: Re: lifted atv craftsman aka marshen June 13th 2014, 6:12 pm | |
| so i was wondering if anybody knows where i can get one one these for less than 60 dollars i was thinking about that (redlinemotorsportts) but i want to to make new mounts for the front end | |
| Subject: Re: lifted atv craftsman aka marshen June 16th 2014, 8:48 am | |
| so in all the other pics it wasnt lifted so i got 4 inch thick blocks in the rear and 2 inch in the front (it is just a mock up not really using wood ) the only reason the rear lift it bigger than the front is because the front tires are 2 inches taller than the rear tires so it levels out this is what it how tall it is in the front and i fixed the tires this is how tall the rear lift is going to be the muffler im going to cut the the small end tip and gut it so its a hollow tube this is ruffly where the shock would be this is the seat until i can find a big back seat this is a driver view this is the complete lift and leveled out | |
| Subject: Re: lifted atv craftsman aka marshen June 22nd 2014, 12:11 pm | |
| so the swing arm with the silver bolt will be mounted in the left hole i took the side panels off so the shock can be mounted the color will be blue cheap kind i want it to look like the atv i got all the parts from i will be cutting the battery hole bigger for the seat so when you are going 30 mph in a turn you dont flip i have a big dirt bike trak so im going to use this as my atv | |
| Subject: Re: lifted atv craftsman aka marshen August 21st 2014, 1:24 pm | |
| so this project hs not been good i havent worked on it for a couple of months i have got a welder hopfully i can pick up a job smart welder soon the motor on this is basacly destryed it needs new rings, new piston heed, new magneto so im going to buy a 22hp v-twin so this is my little update | |
Mike1705 New Member
