| | my past (and current) street rod speed build, Trigger | |
fatboy_dan Member
Age : 46 Join date : 2019-05-13 Points : 1923 Posts : 81 Location : Lone Pine, Washington
| Subject: my past (and current) street rod speed build, Trigger May 14th 2019, 8:00 pm | |
| Trigger started out as a 1991 Wheel Horse 246H built by Toro. Eaton 751 hydrostat with no engine and almost 4000 hours on the chassis as a whole. Originally had a 16hp vanguard. To get it moving I put a modded 28ci briggs in while swapping out the hydro for an MST 206. Eventually I snapped the input shaft tower off the 206, and went to an 801 setting things up as a rally build like the picture below : After a while, it was definitely showing some fatigue in the frame and chassis components so I went all out, taking off a ton of cracking and bent metals to build this 'street rod' speed demon out of it: It ended up getting re-powered with a 22hp intek, ungoverned with upgraded valve springs and a 2.25:1 pulley ratio on the 801, lowered where possible, set with heavy wall 2x4 front axle, ample frame reinforcement and a raked out look. Hit 54.28 before it got sketchy and scared me enough to worry about it. It had a 7" disc brake, mechanical caliper. It suffered a little from sitting, and is going to get a full re-do this winter with a slightly less powerful engine. | |
| | | fatboy_dan Member
| | | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: my past (and current) street rod speed build, Trigger May 15th 2019, 12:07 pm | |
| She looks super mean!! Really cool build!
What are you using for hubs on the rear? I noticed there were only two wheel studs. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | fatboy_dan Member
| Subject: Re: my past (and current) street rod speed build, Trigger May 15th 2019, 12:20 pm | |
| - AllisKidD21 wrote:
- She looks super mean!! Really cool build!
What are you using for hubs on the rear? I noticed there were only two wheel studs. at the point of the pictures it was only dummied up to get photos. it has standard 5 lug hubs that came with the 801, out of a ford/gilson circa late 70's | |
| Who is online? | In total there are 40 users online :: 0 Registered, 0 Hidden and 40 Guests
