| | Rear Pulley Swap on a MTD | |
MTD Scrap Cruiser New Member
Join date : 2017-03-08 Points : 2614 Posts : 3 Location : Cape Breton, Nova Scotia
| Subject: Rear Pulley Swap on a MTD March 8th 2017, 8:50 pm | |
| I was wondering if anyone had any experience with swapping out the rear pulley on one of the mtd shift on the go mowers, i dont really want to touch the front pulley since i have just bought a belt for it and i was only looking for it to go no faster than 25mph/40kph. its probably going to stay mostly stock in the drive-train and wheels department and will be used only for trail riding and not mud. one my main concerns it the pulley being splied and if there is a specif size i need, any ideas?
| | | AllisKidD21 Moderator
| Subject: Re: Rear Pulley Swap on a MTD March 8th 2017, 9:04 pm | |
| The pulley is splined like you said, which would present a problem. Another problem would be figuring out the rear belt size to accommodate the new smaller pulley. Also the vari-drive linkage will have to be re-adjusted as well, but once you get used to it its not too hard to do that. I've done it on my MTD quite a few times. It should be possible for you to do it, it just might be a bit of work. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
| Subject: Re: Rear Pulley Swap on a MTD March 8th 2017, 9:17 pm | |
| Well my MTD still uses the original pulley as it's not really a speed machine, but I swapped in a completely different transaxle all together. I made an adapter so I could still use the splined pulley on the keyed input shaft of the new trans. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 18 users online :: 0 Registered, 0 Hidden and 18 Guests
