| | Almost all cast iron Toro | |
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4731 Posts : 1944 Location : Kansas
| Subject: Almost all cast iron Toro April 24th 2017, 4:48 pm | |
| Got an old beast last week .Transaxle is rusted up but i think once i get it open it will be easily fixed or so i hope . if any of y'all know about them i need info . there is no model numbers on the mower ,only on the transaxle . it has a kohler 12hp cast single , and a peerless/tecumseh 2301A 005008. thats all i know about it . | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8388 Posts : 5190 Location : Ontario Canada
| Subject: Re: Almost all cast iron Toro April 24th 2017, 7:21 pm | |
| Those 12hp (K301) Kohlers are great engines! And that 2300 series Peerless should be a tough old gearbox as well. I don't know what model that tractor is, but I imagine it's pretty stout. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15083 Posts : 10650 Location : Oklahoma
| Subject: Re: Almost all cast iron Toro April 28th 2017, 10:42 am | |
| Took out the transmission and discover significant rust inside . Trying to find replacement gears . If i can get them its going to be Doc locked and reassembled .Thinking about making it a mudder or pulling tractor. The Kohler runs very well and seems to be very durable. | |
| | | MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5554 Posts : 1993 Location : Northern Ireland
| Subject: Re: Almost all cast iron Toro April 29th 2017, 7:42 pm | |
| It is shaft driven to a right angle gear box which belt drives the transaxle .The clutch is on the pulleys that connect the engine to the shaft.I like how very easy it is to work on that way ! | |
| Subject: Re: Almost all cast iron Toro April 29th 2017, 8:36 pm | |
| Cool! That drive train setup with the shaft to gear box to belt to transaxle sounds just like an Allis-Chalmers 700/900 series garden tractor. It's a great setup!
| | | | Customrust Member
| Subject: Re: Almost all cast iron Toro April 30th 2017, 12:17 pm | |
| Originally these were sold as Springfield by quick manufacturing but in 1966 they sold their operations to Toro. | |
