BOUNTY HUNTER UPDATE MARCH 20TH2018 : got a lot done today , new front bumper , built rear bumper , mounted the break caliper , welded up the seam in dash , mounted gas pedal and cable , finished most of the nerf bars , finished up the 40 series CVT install , added 2 more bolts to the front axle plate , wrapped all wiring , relocated the battery tray and finished the tie rods !! if the progress keeps going like this it will be to paint by the 29th of this month !!
biggasmowers Veteran Member
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
this monster Engine connected to an torque converter and from the torque converter on a live axle is a really nice setup. Cant wait to see this Beast running through some mud trails
bow tie mud guy Member
2019 Build-Off Entrant
Age : 53 Join date : 2014-10-21 Points : 3584 Posts : 83 Location : michigan
@SebastianAlbrecht there will be no trail riding with this build , it will be my oval racer for the 2018 season and also used for grass drags this summer !!
If you tell me your sprocket sizes and your rear tire diameter or better yet circumference, I can run the calculations and see if you going to go that fast.
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
@Double W Cross Ranch i will be running a 10 tooth on CVT and a 54 tooth on axle , i also have a 14 tooth for the CVT and a 60 tooth for axle to start out with !! @Crazy_Carl i will be running a 10 tooth on CVT and a 54 tooth on axle , i also have a 14 tooth for the CVT and a 60 tooth for axle to start out with !!
Crazy_Carl Veteran Member
Take a good look at the spec sheet for his 40 series torque converter. I'm not exactly sure what his tire size or driven pulley size is. That would be helpful hint hint. Anyway for a 7.5" driven pulley when the CVT first engages it has a 2.43:1 ratio. As the driven pulley gets up to speed, the gear ratio gradually changes to 1:1.
@bow tie mud guy If you could give me your rear tire size and measure the outside diameter of your driven pulley I could give you some more exact numbers, but here's my first wack at it.
Pretty impressive speeds, but if you ungovern that motor and take it up to 5000 rpm you'll have a real speedster.
@Crazy_Carl the rear tires are 16/6.5/8 x tracks 53 inches round ( out side diameter ) the driven pulley measures from edge to edge across the center is 8 inches
Well I'm not sure exactly what CVT you have, but for now I'm assuming the high ratio in it is 1:1. I re-ran the numbers with your measured circumference, and changed the chart a little bit, There's two different max engine rpms on the left, your two different sprocket ratios are on the right, and on the far right are your four different top speed scenarios. I don't know how long the track you plan on running is, but I'd go with 10 tooth on the CVT and 54 tooth on the axle for more low end torque. You should do a top speed run with the other sprockets anyway for fun at least.
EDIT: By the way if you run the 14 tooth on the CVT and the 54 tooth on the rear axle and wind that 670 up to five grand you might just hit 65mph!
Go to 1:38 in this video. That's going to be you and maybe some other guys in this build off(biggasmowers) too.
Age : 22 Join date : 2018-02-27 Points : 3637 Posts : 1299
thought you want to offroad it, because of the offroad tires.
