| [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] | |
+15Buck muckmudd AllisKidD21 TheBeal mrshaft696 RichieRichOverdrive SebastianAlbrecht CraftsmanQuad19 prancstaman Dave 007 Double W Cross Ranch Doug Crazy_Carl MightyRaze biggasmowers 19 posters |
biggasmowers Veteran Member
Age : 20 Join date : 2017-06-09 Points : 5283 Posts : 2640 Location : Literally Nowhere, Texas
Age : 23 Join date : 2016-12-30 Points : 4721 Posts : 1944 Location : Kansas
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] October 9th 2018, 8:19 pm | |
| Well long time no update, and up until recently (last 4 days) I've finally gotten somewhere on it. All themselves will have to be redone as my machine is giving up what little power it never had and can barely weld 1/8" steel butt joints, let alone trying to get some 90 degree welds with any penetration. So right know I just got the front end locked up and really like the look, rear suspension actually takes up the front movement and should ride well, it does steer some when I just push it around with no weight on it , which I hope means it will turn better once there is a driver on it. Now is the build off timer set for when the build off is completely done or is that till it's closed for posting in the threads? Cause 54 days left seems past the closing time but I have no idea | |
Crazy_Carl Veteran Member
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3352 Posts : 825 Location : In the shop
mrshaft696 Established Member
Join date : 2016-07-10 Points : 3850 Posts : 870 Location : Phillydelphia
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] October 10th 2018, 9:43 am | |
| - biggasmowers wrote:
- Yeah same ! When does the build off end tho? The timer says 54 days but is that till voting starts or what?
Thing looks cool, what kind of seat are you doing? And I assume the 54 days you have to have a walk thru video complete? | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] November 15th 2018, 3:52 pm | |
| As it is getting down to the wire I figured i should start working on it again. Just re welded all the front end stuff so it's not going to break with me on it, cut off and moved the coilovers top mounting points in order to even out the swing arm. Currently I am working on handle bars and footpegs. It's going to be close but I might make it in the next weeks. | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] November 24th 2018, 5:00 pm | |
| Well.**** ......time for the oppy again, now in the last 6 days I have to rebuild my spare oppy and install it. I predict some very late nights ahead. Did have it driving, wired up, all cleaned up until this lovely little flathead decided it was done, governor was busted so I was using it ungovenred and it took enough. fun times. | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] November 26th 2018, 10:24 pm | |
| Oppy is on, getting welding wire, fuel line, oil, spark plugs, and a few other odds and ends tomorrow, if it all goes to plan I should have it in a qualifying state by Wednesday. Adding the hand throttle and hand clutch once I can weld again. Here's a neat pic I snapped tonight. | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] November 28th 2018, 2:59 pm | |
| It's is running and driving, starting, stopping, meets all of the build off requirements but I have to get the correct video to eliminate the belt slippage due to using type B pulleys with a type A belt. Have a short video of it driving just in case the new belt doesn't work but until then I will hold off on posting it if the new belt does fix the slippage issue. | |
| Subject: Re: [Complete] Snapp Dragin RER Death Trap [2018 Build-Off Entry] November 28th 2018, 5:37 pm | |
| From what I've seen, she's looking great so far. There are a lot of sweet ratty touches like the foot pegs, clutch handle, front fender, etc. Also the Snapper sticker still being visible on the rear portion of the frame is a neat touch as well. Definitely a rat rod trike all the way.
Good luck in the votes!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
