| [Complete] Beast Mowed by Jason Kahler [2018 Build-Off Entry] | |
+3MightyRaze muckmudd Offroad MudMowers 7 posters |
Offroad MudMowers Member
Age : 20 Join date : 2018-01-09 Points : 2391 Posts : 81 Location : Washington
| Subject: [Complete] Beast Mowed by Jason Kahler [2018 Build-Off Entry] February 1st 2018, 11:22 pm | |
| This is my first year of the ATLTF 2018 Build Off. I will be entering my Garden Tractor named Beast Mowed. It will be powered by a 25hp briggs OHV twin and a 633a transaxle. I will run 16x6.5-8 X-Trac's up front and 25x10-12 Executioners for the rear. I will be locking the differential, most likely doing a 5 link suspension setup, bumper with lights and a winch and painting this sucker black and red. I will be tearing it down a lot further to get it painted, and assembling from there. Other than a gas petal, rear rack and a few minor things I'm hopin this thing will dominate anything ahead of it! Hope you guys have lots of fun building your rigs, I sure will! Watch my videos I upload to keep updated with the build! https://www.youtube.com/c/OffroadMudMowers -Approved by Doug, 2/2/2018 | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3352 Posts : 825 Location : In the shop
Age : 23 Join date : 2016-04-12 Points : 5746 Posts : 2619 Location : Indiana
| Subject: Re: [Complete] Beast Mowed by Jason Kahler [2018 Build-Off Entry] February 4th 2018, 8:03 pm | |
| The setup on my GT is a bit different on the engine side due to it being a horizontal shaft, but it still has the same clutch and belt twist. It actually works very well. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Dave 007 Member
2017 Build-Off Top 3 Winner
Age : 60 Join date : 2017-02-02 Points : 2772 Posts : 115 Location : Australia
| Subject: Re: [Complete] Beast Mowed by Jason Kahler [2018 Build-Off Entry] July 25th 2018, 6:42 pm | |
| Hey Build-off Participant! Just doing a sanity check to see if there are any new updates! "Nothing new to update." is and update! Just making sure everything is OK since you have not posted in a while.
Thanks! ATLTF Administration
*Other members, please refrain from posting until the original poster makes a comment. | |
| Subject: Re: [Complete] Beast Mowed by Jason Kahler [2018 Build-Off Entry] August 24th 2018, 6:33 pm | |
| Got a quick update on the 633a. I popped it open, and pulled out the Differential. Going to mill two 1/4 or thicker steel plates that will have 6 bolt holes and a cut out for the gear on the axle shaft. I am going to throw out the small differential gears and replace them with the two steel plates. This should work great, I've just got to design a plate in Solid Works, and cut two out. No welder because I blow up too many welded diffs. | |
Crazy_Carl Veteran Member
