| [Neighborhood Watch 3.0] Offroad Mud Mower Build | |
+3CraftsmanQuad19 AllisKidD21 Hillbilly Offroading 7 posters |
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2645 Posts : 582 Location : Reeses Mill, WV
Age : 25 Join date : 2016-07-10 Points : 8379 Posts : 5190 Location : Ontario Canada
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build December 10th 2018, 9:47 pm | |
| Good to see you didn't have any trouble making up a build thread.
Nice groove job on the new tires! They look kinda neat. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 23 Join date : 2016-04-12 Points : 5747 Posts : 2619 Location : Indiana
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build December 10th 2018, 11:58 pm | |
| Well, I took out 7 teeth in a row on 3rd gear doing a wheelie. That was a 920, but same gearset I believe. Also not good for your front axle, coming down that hard. The front ends are notoriously weak in those tractors, but easy to beef up | |
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build December 11th 2018, 8:48 am | |
| The cast iron front axes aren’t as bad as the stamped steel ones. Those are garbage. But the frame itself is a little weak right over the axle. On the mk2 I’m welding angle iron along the whole top angle of the frame. And while you have the welder out, on the front two corners of the frame where the two pieces of metal were just bent to make the corner, just weld them together. I’m adding angle iron here too for extra beef but you wouldn’t have to.
@maine mud mower (redneckcomputergeek) did a whole video on reinforcing these frames, may take a look at that | |
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build January 5th 2019, 12:48 pm | |
| I installed bigger fronts, trimmed hood, and installed a wheelie bar rear rack. Also I have a question. Is there a way to edit the title of my thing? Its not a 1997 like I thought it's a early '00s. Thanks in advance. | |
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build January 5th 2019, 2:20 pm | |
| You should be able to go back to your original post and hit the edit button, that will allow you to change the title. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build January 29th 2019, 10:24 am | |
| Oh boy, looks like one of the counter balancer weights sticking out there. Whoopsies, haha. The 18hp should be a good replacement though! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5125 Posts : 2561 Location : Rochester, New York
| Subject: Re: [Neighborhood Watch 3.0] Offroad Mud Mower Build January 29th 2019, 10:40 am | |
| @AllisKidD21 18 horse ran good before I took it off the Troy-Bilt 8 months ago. Took me awhile to get it started once I installed it on the southern States but it runs good now. It's basically the same engine except a half horsepower higher and it comes equipped with oil filter. Yeah whoop see for sure LOL. | |
Age : 49 Join date : 2016-09-06 Points : 15057 Posts : 10635 Location : Oklahoma
