| [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] | |
+11mowerjunkie03 prancstaman mr.modified Creepycrawler MatthewD SebastianAlbrecht AllisKidD21 Double W Cross Ranch Hillbilly Offroading MightyRaze Offroad MudMowers 15 posters |
Offroad MudMowers Member
Age : 20 Join date : 2018-01-09 Points : 2402 Posts : 81 Location : Washington
| Subject: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 1st 2019, 10:31 pm | |
| Here it is! A new year, Second for me! So this year will be my 4x4 tractor, "HondaX4". It will feature one of those sweet All Wheel Steer trans axles up front, and a standard 930 (I believe) in the rear to match ratios. Will be putting a 3/4 inch axle in the back trans to widen the wheels in the back, to match the front, and have some pillow blocks to accommodate. Honda 14hp (360cc) Liquid Cooled 2 cyl. engine will be powering a Right angle gear box (RAGB) and will have a jack shaft with 2 pulleys, one for each tranny. Each tranny will have its own belt and clutch leading to the gearbox. Haven't decided which ATV tires to run yet, but will be something somewhat aggressive in the 20-22 inch range. Front tranny is 90% going to be welded/locked because this will be a solid frame, without any articulation for simplistic sake. I can't run a 3/4 inch axle in the front because these have splines for the universal joints. Other than that, a few smaller things like a gas pedal, honda fenders with a craftsman hood (honda hood is beaten up) and maybe some fresh paint If I get the time. So, good luck to everyone else entering. Excited for the 2019 build off! I will be posting updates on my YouTube channel :https://www.youtube.com/c/OffroadMudMowers, and on the forum. Approved: MightyRaze 2/1/2019 | |
Age : 49 Join date : 2016-09-06 Points : 15087 Posts : 10653 Location : Oklahoma
2019 Build-Off Entrant
1st Place Build-Off 2020
Age : 22 Join date : 2018-11-09 Points : 2655 Posts : 582 Location : Reeses Mill, WV
Age : 20 Join date : 2017-06-09 Points : 5294 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 2nd 2019, 9:19 am | |
| Dont lock the front end, it wont be able to steer. People have done it. Lock the rear end, because without articulation, one rear tire could easily be off the ground. Nice engine. What tractor did that frame come from? | |
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 2nd 2019, 12:17 pm | |
| Thanks guys. The frame/tractor was a Honda 4514 and it needed the engine pulled because the water pump was loose. Took a while to strip down, but was impressed to see how one was built. Only reason I thought of locking the front too is because the front wheels might become useless if one picks up off the ground, being that there will be no articulation. | |
Age : 25 Join date : 2016-07-10 Points : 8389 Posts : 5190 Location : Ontario Canada
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 2nd 2019, 12:44 pm | |
| Sweet looking frame, pretty automotive looking. Should be a neat build for sure.
Good luck!! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 22 Join date : 2018-02-27 Points : 3648 Posts : 1299
MatthewD Veteran Member
Age : 22 Join date : 2014-11-16 Points : 5555 Posts : 1993 Location : Northern Ireland
Age : 36 Join date : 2013-07-02 Points : 4821 Posts : 731 Location : Logan Ohio
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 8th 2019, 4:43 pm | |
| personally Id lock the front, like said, with no articulation anytime it picks up a tire the front wont pull, Ive ran trucks and sxs with welded front diffs and they suck to turn, but they will turn. Id guess youll mainly be using this as a true mud tractor and not much of a rally or cruiser, so the trade off would be worth it to me. maybe even gear the steering down a bit ? just spitballing here | |
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 8th 2019, 4:49 pm | |
| - Creepycrawler wrote:
- personally Id lock the front, like said, with no articulation anytime it picks up a tire the front wont pull, Ive ran trucks and sxs with welded front diffs and they suck to turn, but they will turn. Id guess youll mainly be using this as a true mud tractor and not much of a rally or cruiser, so the trade off would be worth it to me. maybe even gear the steering down a bit ? just spitballing here
I wouldn't lock the front, since it's putting tons of stress on the steering knuckles, when torque is going through them and the Tires dont want to turn... the crap wo'nt last long! | |
| Subject: Re: [FINALIST] - HondaX4 By Jason Kahler [2019 Build-Off Entry] February 20th 2019, 11:53 am | |
| New update video!!
I will be ditching the RAGB to save money and using a simple belt twist. This will still use only two belts, and be really really simple. Also got new OEM seals for the honda that where leaking. Next up, going to open the differentials. And maybe even get the trans axle mounts welded and test belt ideas.
Update: just noticed the video rendered without any audio, Dang it! Hopefully will have it out tonight or tomorrow morning.
